1 members (Olqualcast), 11,484 guests, and 1,616 robots.
Some more for the Mystery.
Ive been doing some more research and came up with 3 fairly solid conclusions.
Two have been mentioned,the third has not,and I think is the final piece.
1. What we currently know as Model 6 or V code 6 has the later MK10 engine. One piece barrel and the Engine that directly followed the model 5 series engines.
What we know as Model 9 or V code 7 has the earlier MK9 125 engine and barrel with the port covers.
2. The Newer more modern streamlined cowl design with inbult tank,would surely have been a later design.
3. Blumbly posted this image in a previous thread.
Now the Image shows the Model 6 or V6....But if you read the lower info about "When Impulse starter is fitted use " blah blah drum" My point is that NOT in any example or document did the Mower we know as the model 6( tank in cowl) EVER come with an impulse starter. The "sure start" impulse was only fitted to what we currently know as Model 9.
4. Im also of the opinion that engine numbers will not be relevant since both models ran side by side... but more examples may help..So the two models may not run in sequence.
Please let me know your thoughts and any other numbers to back up the sequence of 6 and 9.
So at present Im leaning now towards the models being the wrong way around. "Sure start" and tank on cowl model 6 or V6.....Streamlined tank IN cowl and later 125 MK10 Model 9 Or V7....
What do you all think? Please offer your thoughts. I have both going currently and want to get them correct.
Well I don't know if I've put this in above but I have noticed is that the one we have been calling the model 9.With the engine numbers they have letters in-front of the numbers.As did the last of the model 5's.That has been the case in the one's that I have found.Not sure if that's what your saying as well Blue.I don't know if there will ever be answer as to why Victa started one way then changed to another.As it seems to be that is what has happened,but why?
Thanks Blumbly,appreciate the imput...Im Unsure why they changed,maybee it really was a misprint,But why it changed isnt as important as determining the Correct models.
The fact that the image states the use of the Impulse starter as an option for the Model 6 (tank on cowl) as per diagram,to me says that it is actually as the document suggests..A Model 6,Not 9. No other document shows this. I think this is a very important piece of information.
My engine nos all have letters in front irrespective of model. 3 are actually DAB...... So I dont think the answer lies in the Engine numbers. The ones with the numbers only to me would suggest a later engine as this is when the date codes started,so if anyone has a model with this full number sequence please let us see what model it is on. Im now almost certain the the answer lies in the starter types Especially since the model we currently know as 6 (Tank IN cowl) NEVER came with this starter type(impulse).
..Get me?
But not all of them had impulse starters.I have had five so far and only one had the impulse starter.
For sure they did not,it was an option...But what im saying is the model we currently know as 6 (tank IN cowl) NEVER had the impulse as an option. The Manual Image I posted clearly states that the sheerline model 6 (the one we currently know as 9) DID. So I think this is the correct Image to suit the Model 6. Anyway ill keep chipping away and see if I can find some more evidence to support this Manual Picture.
Does this help at all?
28 Oct 1960
Yes unkie it helps,but what the ad doesnt state is if its a model 6 or a model 9 frown Im going to continue researching this until I find the answer for sure and then start a sheerline thread when Ive gathered more info,just The Automatic and Roto one smile
well if victa done things in order we should say that that model being the first release , that it would have been the model 6 ?
Yes Tomo We would assume so,but many members have voiced opinions in regards to a reversal of the models due to inncauracies in the Manuals.. I have 4 now and a few more image/serial examples,so Im trying to get any clues I can with serial and others directly from the mower.
The real trouble is they ran side by side,so while the numbers may be in sequence,they are shared by 2 models. I have some examples of lower numbers on model 9s and vice versa. But in my opinion they are more than likely the way we have always known them to be smile Pretty much everything else is known about sheerline...So I dont think there will be any other great mystery.
The main clue in this Ad is the date,And as you said the term "First Release" Also they were still selling Specials" up until and even after this date. So I think this shows that this may well be the first AD Depicting A "Correct Model 6". I Really think this is enough to verify Its accuracy And should be treated as such until Someone could prove conclusively That it is not:) Case closed?
I had been told previously by some that the model 6 and 9 bases were different. If you look at blumblys Image,It states The same Number chassis as being 6' For both models pictured smile. This will verify other memebrs attesting to their model 6 and 9s having the same base types. While their are 2 chassis styles for sheerline,this clearly proves that both models recieved the same chassis style at some point smile
i agree ive seen a few body mix matches in them ,if we could ever get close to an answer id say that calling our "first release" here our model 6.
what a nightmare.
cheers tomo
well here's what it says in my 1971 green book, same engine, same everything??
sorry guys no help.
This may just close the case on this thread. As it pictures the Sheerline on its original release, It would appear that the Model 6 designation would logically apply to the model pictured, with the externally mounted fuel tank.
June, 1961
It looks to me like the back room boys got their Green Book images mixed up in later years.
Hi bestseller
There must have been a lot of 'discussion' going on about the Victa Range.
The earliest Victa ad I have for the release of the Sheerline dates from
14 October, 1960. The next 6 November, 1960.
The TV advert also presented the Sheerline with the streamlined cowl.
The June 1961 photo depicts the 1961-62 range, suggesting that the
external fuel tank Sheerline is the later model.
p.s. the anomaly in the 1961-62, for me, is the Standard & new Utility.
Surely two utility bases could not last - it made no sense.
So, I guess, the Standard was dropped for the 1962-63 season.
All very confusing.
2-stroke mower addict!
I picked this sheerline a few weeks ago. It's in rough shape but I can definitely work with what I have to restore it to a very decent looking specimen. Very disappointing that the original badge was broken recently before I purchased it and was thrown away.
I also picked up what appeared to be a standard of some type. I do see that there is a sheerline style standard but this one I have picked up, for free, has the opposite model cowl than the one in the manual and advertisements I've seen.
18,232 Registered Users
Topics12,777
Posts106,881
Members18,232
