1 members (auProspector),
655
1,931
Mowbile
Hi...does anyone have a Victa Utility Base?..am restoring a Victa Utility...from around 1977 to 1984?..hard to get hold of so hoping that someone here mayn know of where I can locate one...the pics below are just a sample of what I am searching for,any steel utility base that will acept a 160 cc motor will do...am willing to modify to fit...have all the parts I need except base and blde disc...can anyone here help?..with thanks...Hans from Cairns ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/01/full-6428-9534-t2ec16jhjie9qso8dvqbqt9qio_hq60_3.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/01/full-6428-9535-full_6143_7674_1.jpg)
Posts: 1,819 Likes: 6
So the one you want is the bottom one???
The top one is a power torque which is 160cc. The bottom one is an early utility and could be 125 or 160cc.
So do you have a power torque or a full crank motor??
Theres 2 different bases in between them.
A rear facing stamped base thats pretty much the same shape as the top one but for a full crank. A side facing base thats the same as the top one but for a sideways full crank.
If its either of the above you might also need the right disc for it as the regular over later ones off a catcher mower dont fit, the upturned edge hits the handle bolts.
I do believe I have a couple of those in betweens here, might even have one the same as the bottom pic.
Im in Melb, if you want me to look please send a PM.
Cheers, Bob.
Posts: 4,291 Likes: 4
Yes it would help if you let us know exactly which one you want. As there is enough collectors on here to be able to get the the right base. Also if we knew the correct model could even get the right cutting disc. You won't have to settle for second best,as what you are looking for isn't rare and should be able to be found quite easily.
Mowbile
Hey Bob and Blumby...it's the bottom pictured base I want...would be great to get the right blade plate for it as well. I have a full crank motor...sorry about the top pic, thought it wasn't a power torque. Basically want a steel utility base for my full crank 160... doesn't have to be exactly the same as the pic
OK cool now let the search being.Now I know I don't have one as I got rid of the ones I didn't need due to us moving,but I think you may have better luck with bob.Good luck with the search you should be able to get them as there not that hard to find.
OK mowbile this is getting confusing you have two threads open saying you want a utility base,but in both threads you've put pictures up of the base you want.Both bases are different to each other.So I think we all need to know exactly what base your after and to close one of the threads down.As we don't need two threads on the one topic.It's getting way too confusing.
Mowbile
Am looking for any steel utility base that will suit a full crank 160 cc Victa engine...age and model not that important as long as it doesnt have too much rust and is suited to restoration. Would like one that allows the engine to be mounted with spark plug facing the rear of base. All other posts I have submitted can be closed down...sorry for the confusion.
Topics12,750
Posts106,779
Members18,091
