0 members (), 494 guests, and 853 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Page 2 of 3 1 2 3
Joe, I agree it should work very well as long as the teeth on the jaws are sharp, but I don't see what advantage it has over an ordinary Stillson. The demonstration test on the prototype Stillson that convinced a tool manufacturer to licence and produce it, was proving that if you clamp a piece of waterpipe in a pipe vice and apply a Stillson to the other end of the pipe, you can easily twist the steel pipe until it breaks.
Stillsons are rather clumsy in my opinion, so I seldom use one until one of my trusty gas pliers has failed to do the job. Either a Stillson or a gas plier will easily bite into mild steel to the depth of the teeth on its jaws, then tear off that amount of metal right around the object it's gripping. Of course that is rather uncomfortable on your hand in the case of a gas plier.
Hi Joe, would that be a grey bonnet I spy?? lol
OK, so finally got the engine off.. !
rebuild is underway ![Linked Image]
Had the frame welded, and looks strong as ever
Am in the process of stripping/ cleaning all the parts. After seeing some video's online of people using electrolysis thought I'd give it a go. Works a treat, after about 4 hours.
Had a question, how have people restored their body plates. Mine is the older style which has two overlapping each other
Hi Barry Jnr
Yes I would be very interested on how to restore the Serial Number plate as well.
Is there a special place or way to have them done properly?
If anybody knows would be great
Jason
Hi guys, Scott Bonnar ID plates were etched from brass originally and had a bright red painted background. When the plate is in very good condition, this could be restored by masking the larger section where the numbers are stamped, spraying the whole plate in bright red enamel, and when completely dry, after removing the masking tape; rubbing the plate on wet and dry paper, on a flat smooth surface.....to reveal the lettering in brass.
When the plate has been damaged ie. dented, bent or abraded, a polish to a high shine with 'Brasso' will do the trick and look great....showing the heritage of the machine. wink
The later Scotties/Rovers had an anodized aluminium ID plate and restoration is nigh on impossible if damaged. cry
The 2 plates that Barry has riveted together were brought about by the inclusion of the new Model number sequence. This info of course carried over to the anodised future plate. wink
Thanks Deejay, sounds logical in theory however my lettering doesn't seem to be raised that much, feels very flat in fact..
Ok, reel now sandblasted, as is frame
Some work on the chain guard
First attempt using a spray gun...very light first coat
Slow progress, but here is the reel
It's off to the local shop for a grind....
Looks pretty good so far, I have to have my reel straightened before i paint it, yours looks pretty straight smile
Hi Barry, congrats on the job thus far mate....This machine will look a treat when finished!
good1
Had a visitor while building... Bread didn't work, so had to resort to a broom
That EH Premier is looking pretty good. My father had one just like it, even the same colour. No rust on the sail panel by the look of it.
Thanks Grumpy. Yep the EH prem is my baby, well second baby behind the 45 at the moment.....body is pretty good with only a few small rust spots.
On the re-assembly at the moment. Getting excited
In regards to my earlier post, based on some advice, I sanded back the ID plate and left unpainted. I'll try and take some close up pics
Hope to get the motor installed, and align the reel and sole plate on the weekend. The new turf is almost ready for a mow!!!
Hi Barry, all looks to be coming along nicely....good work, mate. grin
Just a tip, make sure you completely reassemble the machine; less the chain case cover of course, before you attempt to adjust the reel clearances. Here is my method...Click HERE
Good luck with it and please let us know how you get on. wink
Thanks Deejay
Yep assembled the entire unit and will play with adjustment as the last step
The new Briggs bolted straight on. Can't wait for the first fire up
Barry, please don't forget to check the crankcase oil level in that new engine. Briggs engines are normally shipped with dry crankcases, in case they are tipped in transit. An amazing number of them are fired up for the first time without putting oil in them. I understand you can't claim warranty if this happens, because the owner manual emphasises the necessity of doing it.
Also Barry, install the grass deflector and the catcher support rubber blocks, you will scratch the catcher if you forget. wink
Looking fabulous mate! good1
Thanks guys
Grumpy, have purposely left the new sticker on the engine as my reminder to not start without oil, new engine has a dipstick vs the old Tecumseh. And yes comes Dry.
Deejay. Have brand new catcher rubbers ready to go and will take your advice from your video about grass deflector after reel adjustment
Also realized I'd left the rubber off the crank, so need to take engine off to refit
All Done....
Have since used a couple of times and works a treat. The new briggs is nice and quiet (smoked a bit on first fire up, which marked the newly painted handle stem where the decal sits), compared to the old Kirby.. Tweaked the reel alignenment after the first mow, which made a huge difference.
Still do do is
-add the throttle control from handlebar, but is not a huge priority..
-oil change in a few weeks
Polished badge
Page 2 of 3 1 2 3
markalan28, Taras, Tool, Blakewell26, Aaron.
17,720 Registered Users
Topics13,031
Posts107,113
Members17,721
PHP: 8.3.27 Page Time: 0.037s Queries: 55 (0.029s) Memory: 0.7300 MB (Peak: 0.8343 MB) Data Comp: Zlib Server Time: 2025-12-13 12:28:00 UTC
