1 members (DFB), 1,550 guests, and 642 robots.
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
by NormK - 22/10/25 03:29 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
by NormK - 17/10/25 08:56 PM
Rotomo crank shaft
#39075 16/08/12 09:03 PM
I have a Victa with the plastic carb, got all the new rubbers and I know it's installed properly but it still won't cut out.
The wiring on the coil had come off and I'm wondering if this could be the problem. The black wire stayed on but which way do the brown and green ones go? It still ran with both off, just wouldn't cut out.
What the hell, it runs!
I've been thinking about it and it shouldn't matter which way the wires go, should it? And I know the rubbers in the carb are good there brand new. I just did the ones on my tilt a cut, so i know how to do it properly. It's got me stuffed!
The two wires on the coil are different lengths and it should be obvious which way they sit once placed on, all wires need to be connected for the ignition switch to work at all.
Ok, Well I did put the wires the way that I thought they should sit; maybe I'll try them the other way...
Ok, I got it right, but the grey wire came off again. So for anyone with this prob again, the black wire goes to the coil closest to the motor when the coil is fitted. The grey; to the coil closest to the blade plate, and the brown wire separating off of the grey wire, goes to the metal bit in the middle of the coil.
Hi Michael_xr8, and a warm welcome back to the OutdoorKing forum. It's been a while since we have seen you posting. grin
Thanks mate, for letting know that you have got it sorted, and for posting the solution for our archives.
As this thread is now complete, I will now close it. If any member has anything to add, please PM a Moderator. wink
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Maudebs, Greenarrow01, stkarl, Stannyboy, yaapeet30
17,640 Registered Users
Topics13,009
Posts106,969
Members17,640
PHP: 8.3.26 Page Time: 0.039s Queries: 27 (0.033s) Memory: 0.6400 MB (Peak: 0.6761 MB) Data Comp: Zlib Server Time: 2025-10-22 07:46:14 UTC
