0 members (), 6,044 guests, and 1,924 robots.
by nath - 16/10/26 10:48 AM
Well the mystery continus went to start it last night and once again no starting. However this time I have a theroy as to what is causing this. I'll let you all know if I'm right.
OK well I know have do it this time.After just taking a step back from it I had a good think as to what might be the problem.Then like in those Warner Brother cartoons the light bulb was above my head.So I pulled it apart for the third time.I even pulled the plate off and then started making up a new gasket,as the theory was the gasket I put on the first time wasn't doing its job.I don't even know where I got it from.My theory was replace the gasket as maybe there was a vacuum leak through that gasket,as that is what started this hole problem.So I got (Prum Prum) back together.Now I did cheat and added a little spray of start you bastard.On the first pulled it was alive!! I ran it for a few seconds,then stopped it.Primed the carby and started straight away.Them mowed most of my lawns (just lazy so I didn't do it all).Waited a few hours and started it again,all good.So mystery solved it was a vacuum leak through the first gasket I put on it.The second gasket is all good.Once again thanks for your help we got there in the end.
amazing what standing back and a good scratch will do wink great to hear it doing the job again grin
Small Engine Technician
I knew you could fix it Blumbly!
grin
Thanks guys I knew I'd work it out. I guess I was just trying to get done to quick as I have a lot of mower jobs on at the moment. Next time ill just take my time. Make sure the new gaskets is good enough to do the job.
Abp5961, RossL, MartinWes, REG1, Ricko
18,166 Registered Users
Posts106,819
Members18,166
