1 members (MowingManiac), 2,581 guests, and 320 robots.
by Widget - 03/11/25 08:12 PM
by Ghost - 25/10/25 07:11 AM
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
GCV 160
by NormK - 07/11/25 03:53 PM
Lower Crank Seal - Sprint 35
by NormK - 05/11/25 08:17 AM
by NormK - 25/10/25 09:57 AM
by NormK - 22/10/25 09:06 PM
#3384 13/08/02 05:10 AM
A
Anonymous
The flywheel key on a 4hp Briggs and Stratton keeps shearing. Does anybody have any idea what to look for to fix this? Any help woould be appreciated!
#3385 13/08/02 10:12 AM
Are you trying to run the motor without the blade plate on?
If so you will continue to shear the flywheel key.
If the boss on the blade plate has movement in it shear as well.
I hope that this will help.
#3386 18/03/03 11:13 PM
wal Offline
I have found this a common problem with 4 hp B@S motors with the alloy key. I always clean the crankshaft taper and the inside of the flywheel and the key with lacquer thinners to remove any trace of oil, no more problems. You must also make sure the retaining nut is very tight.
cheers,
Wal
#3387 18/03/03 11:19 PM
wal Offline
cheers,
Wal
SuziRova, Buttercup, Calais346, Gregtyu, notausername
17,655 Registered Users
Topics13,014
Posts107,001
Members17,655
PHP: 8.3.26 Page Time: 0.022s Queries: 22 (0.016s) Memory: 0.6250 MB (Peak: 0.6507 MB) Data Comp: Zlib Server Time: 2025-11-07 19:54:07 UTC
