5 members (MowingManiac, Ausmow55, Buckets, AMP, 1 invisible), 1,793 guests, and 415 robots.
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Rover Thoroughbred Model 85
Sanli Redback Ret Spring
by Ausmow55 - 22/01/26 09:42 AM
by AVB - 22/01/26 02:15 AM
by NormK - 21/01/26 09:55 PM
by AVB - 12/01/26 08:30 AM
Heres another trick
8mm bolt, cut the head off it and put a slot in the top with a hack saw.
Handy for putting motors on and of bases. Not so good for the later ones wit hthe long bolt behind the muffler as you need to use a different hole.
You can also clamp the bolt in the vice and fiddle with the motor, good for testing spark if youve had it flipped over on the bench messing with the coil or coil lead.
Doesnt matter if it gets a bit trashed, its easy to make another one.
This trick works for most mowers.
Trusty block of redgum. Set the height lever so its straight up and down. Tip the motor sideways and rest the height lever on the block of wood. Works on victas and rovers and the like.
Well I must say bob you are full of it.................advice that is. You do seen to know a few handy tricks. Good work.
You can also do the same with a 3/8 bolt for the later 4 strokes.
VNDRFNK, emiks-3, Larko, Ehdik, Damien78
17,804 Registered Users
Topics13,057
Posts107,233
Members17,804
PHP: 8.3.28 Page Time: 0.041s Queries: 21 (0.036s) Memory: 0.6375 MB (Peak: 0.6561 MB) Data Comp: Zlib Server Time: 2026-01-21 23:18:50 UTC
