5 members (Mark Tasmania, Bruce, Olqualcast, MarkusB, Nick James), 10,302 guests, and 1,735 robots.
Hi guys,
I have a fairly simple question I think smile
I have sourced a late model VSX160 Victa Tornado with a blown motor. I have also sourced a rebuilt block from a 2003/2003 V160 Victa Vantage.
From looking at the blocks they are identical apart from VSX160 using a different spark plug?
My question is can I use my rebuilt block from older modely V160 and fit it with all the other parts from the VSX160 and have a complete running engine?
Thanks heaps!
Should be fine, I imagine theres some technicality that would mean that the engine would not be an exact VSX-160 (I think they made som barely visible port shape alterations for the VSX) however that will have no effect in this situation, in fact i doubt you will notice a difference in running when you are done.
Make sure you remember to swap over the intake port, th VSX is straigh, not elbow.
Excellent! I will re-fit the intake etc as it was meant to be.
first NOT the voice of experience here but since you "?"
(I dont have much of a clue at all really well practical wise)
on Different spark Plugs?
on a bit of searching
Champion CJ8 (some here prefer to use NGK BM6A I think it is)
was pretty much it 1980 to 98
but seems 1998 a few different ones may have been used
(motor changes, Eco more friendly and moving production I suppose)
1998 ~2002 RCJ8Y (Champion) *
2002 ~2004 RCJ14H (Champion)...your era motor 2003 *
2004 ~ NGK BPMR4A (seems you can use this backwards to 98)*
here's the NGK meaning of all the digits
http://www.ngk.com.au/sparkplug.php#
(* all are resistor types)
now I did read somewhere that a hotter plug
(and 4 means hotter in NGK)
might lead to less fouling of the plug
(and down sides no idea)
but well its hear say to me and could really mean Ducks walk backwards too..
Although it kinda fits the logic of the less customers annoying you with problems the better.....
so maybe
I'll leave that to someone that knows and this is only info I gather off the net..so I wouldn't say its gospel
but hope that helps with the "Plug ? mark"
Cheers smile
Edit: Side point
humm rather interesting reading the last part of this on spark plug with resistors
http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqresistor.asp
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
uquote
electronic control I guess..they mean
Not that Id think a 2 stroke would care...but interesting
(I'll stand to be corrected thought)
This does raise the question though
to me anyway where in lies the difference in year the 1998
why they stated only backward till then...
if the Engines haven't really change
and well I got a funny feeling now the original
in mine was RCJ8Y...
couldn't get one and have been using CJ8's
I know ours was pre 2K a year or two on the dial
Anyway another side point
Again Cheers smile
If it ain't Broke Don't Fix it...
Sometimes I wish I'd listen to myself
rebuild has been completed and mower is running great!
thanks for everyone's input smile
Good to hear!
and many short lawns to you mate
may it serve you well
Cheers smile
18,232 Registered Users
Topics12,777
Posts106,881
Members18,233
