8,239
695
have a victa 2 stroke mower with plastic g4 carby. It will start but then stop, if i push and pull the mower forward and backwards it will idle erratically but wont stop till i stop jarring the mower also if i prime the nipple it will stay idling till i stop priming. if i replace the spark plug the mower will last bit longer then fowl up the plug. the primer face of the carby originally was leaking and replaced the primer face with new needle and o ring. Still same problem, the cut out wires that plug into the carby, the boot is perished and if i move the wire in and out the mower somewhat will stay idling until i stop moving the wire. I replaced fuel and cleaned the tank, got good compression and good air filter. still no go, fuel tap is good and flow is ok. obviously something wrong with the carby. can i get help and maybe get instructions on pulling apart the carby for service and positioning the cut out wires and maybe how to access main jet..
Posts: 5,419 Likes: 36
dristo72, Under this section you have an area called parts list and repair manuals that will help you with your problem regarding the carby. This area is available to members of the board that have access. All we request is a small donation to the board.
Can i get information / diagram on the g4 carby emailed to me, since i require to fix the mower asap. its an actual friends mower and he is hounding me. If you can and then in couple of days i can make a donation. thanks for your help
sorry my email is dristo72@hotmail.com
Hi, I have just made a donation, can you specify how i can get access and the information.
thank you
dristo72, You now have access to the parts list and repair manuals in the Victa lawn mower section. Just use your user name and password to access the area.
Topics13,080
Posts107,356
Members17,924
