0 members (), 4,929 guests, and 1,523 robots.
My Victa Commando starts beautifully first pull. However, it will not restart if it runs out of fuel and needs to be refilled or if I stop it and try to restart it. I have to wait till it cools down and then go through the cold start procedure and off it goes beatifully.
As you can imagine this can be very frustrating. Is there anything I can do to remedy this problem.
Many Thanks,
Rod.
rod4655,
1. Sounds like the needle is sticking in the carby.
2. The main jet could be partly blocked.
3. Check the hole in the fuel cap as it also could be blocked.
4. If the mower is old the seal in the bottom bearing could be leaking.
5. If old motor the rings could be worn.
Use the search button and type in carby information and links.
This will give you information on the carby.
Thanks,
Bruce [Linked Image]
[This message has been edited by Bruce (edited 10 February 2006).]
Thanks Bruce,
This mower is 18 months old should this narrow the problem
18,147 Registered Users
Members18,148
