3 members (Buckets, MarkusB, Bruce), 3,738 guests, and 439 robots.
by Bruce - 28/11/26 12:52 PM
#30220 24/10/11 05:01 PM
hi guys newby here i have a 5hp b&s motor with weak spark and it will not start so i think i need another coil so wondering if anyone can help with an old one or good place to get new one near frankston vic.model type code 132922 0134-01 89062207
Have you checked that the gap between the ignition unit and the flywheel is correct (about 0.010") on both sides of the magnetic yoke? Have you verified that the ignition unit is making a good ground connection to the cylinder/crankcase casting? After attending to those points, is the spark blue or red? If the spark is red, or intermittent, or both, a replacement ignition module is likely to be well worth trying. Your engine was made in 1989 so it has a Magnatron (breakerless electronic) ignition unit. I think you'll find it is the same unit used in all of the small post-1983 Briggs engines, so you may find one attached to a dead mower on a nearby nature strip, or otherwise you can get one from your local mower repairer (which he'll have obtained from a dead Briggs). You can buy a new one from the mower guy if you want, but they don't seem to give much trouble so I don't see much advantage in that compared with a used one.
A new coil is over $80.
A used one i would expect to be somewhere around half that.
Check the plug, and double check the plug.
I agree Bob, the spark should always be checked directly from the plug lead to ground, without using a spark plug, before any suspicion falls on the ignition module. Spark plugs die a lot more often than modules - and seem to be a lot more prone to being defective when new, as well.
I sell coils like hotcakes on eBay for 25 I have found it uncommon for the coil to be at fault.
thanks for the info guys i will check these things ang go from there
18,248 Registered Users
Topics12,780
Posts106,888
Members18,248
