1 members (Red Rum),
3,304
419
Posts: 2,738 Likes: 6
Hi Guys, Wondering what information is out there about this mower. All i know, It is a simplex, I have the carby, whitch i will get a few pics up of, I also have the fuel tank, however this mounts on the handles whitch i do not have. I am also missing the muffler, whitch appears to be ball shaped. Does anyone know the era of this machine, and its engine capacity? I'll pop some more pics of it up soon, I also have a Rover cadet with the same engine. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-5013-2478-full_5013_2434_img_0494.jpg)
Cheers Ty
I have a feeling this is the MKI or MKII so that would be 85cc, wow, thats a pretty samll one, I'll have to try and get it running, See how it performs! Thanks Grumpy!
Cheers Ty
OK, well, I have worked out where I will head with this one. I plan to fabricate a new handlebar for it, until I can track down an originall, I also beleve an early Victa 'Hamburger' muffler will fit on this one, so in the meantime, I will try that. I will keep posting on my efforts, anyone got any tips for first-time handle making? Heres some more pictures: ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-5013-2555-img_0492.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-5013-2556-img_0493.jpg)
Cheers Ty
If you are making it out of steel tube Ty, make sure it is mild steel tube. You will need a bender, which can be simple or complicated, but for that small diameter stuff, with long "handles" both sides of each bend, a half-round channel of the correct diameter will be satisfactory. Don't try to bend it without a half-round mould to bend it into, you will just flatten the tube, which looks awful.
For tight bends (in relation to the tube diameter) you need advanced technology (such as a commercial tube bender, and in extreme cases you may need to fill the tube with compacted sand and cap the ends), but that shouldn't apply here unless you want a really strange-looking handle. Be glad you aren't trying to make a set of equal length header pipes to fit into a confined space.
I'll keep that in mind Grumpy, I'm going to start by trying to bend my own tubular handles, as this is more inline with the original design, and i do think i can pull it off, provided i dont try anything to tricky (thanks for your tip with the angles!)
If that fales, it will be 2 flat bars, and a handle bolted between, posibly with a stabilser bar.
Is it possible to make a 'Bender' and how would I make a simple one?
Cheers Ty
You can buy one from your local hardware store, or better, find a second-hand one to suit your needs. Here is how a traditional one looks and works: http://www.ebay.com/itm/NEW-12-Ton-...4?pt=BI_Pipe_Benders&hash=item35b47f0a9aNote the various sizes of half-round dies to keep the tube from flattening as well as controlling the bend radius. Here is the other common way of doing it: http://www.ebay.com/itm/Handy-Holes...3?pt=BI_Pipe_Benders&hash=item2c5eafa7cbThe only difficult part of the first one to make yourself, is the half-round die. You could make one with a rotary table on a milling machine, or just with a lathe. As you can see, the force is provided by an ordinary hydraulic jack. I once made (with an enormous amount of help from my father) a difficult set of car header pipes with one that used a screw instead of a hydraulic jack. In that case though, it was necessary to revise the die on a milling machine because the bends had to be much closer together than it was designed for. You shouldn't have any of those problems, a mower handle is about as easy as it gets.
I mught alrady have something here that could take the part of the radius guide, Thanks for tha Grumpy, I'll let you know how i go making the machine.
No chance you have any tips for pinchine the ends of the bars in to create the flat mounting area?
Cheers Ty
Posts: 4,291 Likes: 4
Here you go.Found some more pictures.This is it before bin time. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-5048-2585-recon_061.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-5048-2586-recon_062.jpg) I've asked Rob if he still has any parts for them.He hasn't replied yet.So maybe not.
Ah, now i know whtich carby is for this one, that throttle controll is very low, it also appears to be a victa one, so i doubt it was originally at that height, maybe somone just did that to salvage an otherwise damaged cable.
Also, that shows the engine now with the Rover Cadet to be the original engine to this one, as it has the blue paint on the cylinder, I though this might be the case, so i will check them both out, and may swap it over.
No chace you have a picture anywhere of the blade disk for this one, I'm not sure the one on it is the one i saw in the ebay pictures whaen it was sold seperatly.
Cheers Ty
Ty, how you go about shaping the end of the tubular handle depends on what shape it has to be. Various squeezing processes are readily available - that tube squeezes flat easily in an ordinary bench vice. The trick is to end up with the shape you want. I notice one of those handles has flat plates welded to the end of the tube, which should be easy too.
Grumpy, I might just leave the welding as a back up, from the phot's i have here, the ubes are simply pressed flat at the ends, in a slightly off-centre way (I think the inner edge of the u-shape continues along the flat bits, while the dip is on the outer edge)
I'll try and dig up some better pictures.
I'm curios as to the tubing that will flatten in a vice, sounds easier, as long as it wont have trouble with the bends!
Cheers Ty
I've always used Dawn industrial vices - they will produce a ton or two of squeezing force. When that runs out, the hydraulic press is only a couple of steps away and it does 30 tons quite easily, but that is its rated maximum. It takes less than a ton to squeeze thin tube like mower handles flat.
To get the tube to squeeze more on one side than the other, you need to support one side. It gets a bit tricky to get the exact amount of offset you want - need to use a spacer, and practice a bit with scrap tubing. For a fully-offset result you'd use a flat support on one side only. (The flat support will extend well beyond the end of the vice jaw on that side only.)
Cheers Ty
Topics12,780
Posts106,888
Members18,248
