0 members (), 652 guests, and 595 robots.
Star Poducts cylinder mower
by Widget - 03/11/25 08:12 PM
by Ghost - 25/10/25 07:11 AM
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Gear Head Maintenance
GCV 160
by NormK - 07/11/25 03:53 PM
Lower Crank Seal - Sprint 35
by NormK - 05/11/25 08:17 AM
by NormK - 25/10/25 09:57 AM
#2643 06/12/04 12:40 PM
I was given a victa 2 stroke mower, i'd like to identify it. It has no model badgeing on it and has a green plastic top deck. The catcher is secured by the hinged metal door on the rear catching a lip on the plastic rear catcher ( i dont have the catcher but my neighbour had the same model). It uses 25:1 fuel mix. I need blade part numbers.
thanks
#2644 06/12/04 06:46 PM
robbie d
If you have a look at the air filter housing on the handle you will see the model number (where the bolt goes through the handle). That will help a lot as I need to tell you the correct blades.
Bruce [Linked Image]
#2645 07/12/04 09:46 AM
thanks willl check tonight
#2646 08/12/04 08:56 AM
the model number is somewhat aged.
the numbers i could get off it are
AF05* AA9*
#2647 08/12/04 09:19 PM
robbie d,
The mower is a Pacer made between 1990 & 1992 and the model nuber is AF055 AA90. The blade type is a CA09306S bolt set is CA09277S. The catcher is GC11697A.
#2648 09/12/04 08:43 AM
thanks bruce.
Replacing the blades should kill the vibration problem it has (i think the previous owner was mowing gravel). the next problem is the smoke, I know its a two stroke but this one smokes enough to fumigate a whole street. any places to check first? air filter, mixture?
17,657 Registered Users
Topics13,015
Posts107,003
Members17,658
PHP: 8.3.26 Page Time: 0.032s Queries: 26 (0.026s) Memory: 0.6406 MB (Peak: 0.6756 MB) Data Comp: Zlib Server Time: 2025-11-09 03:46:36 UTC
