1 members (Commspares), 7,737 guests, and 149 robots.
hey guys how is everyone
like mentioned above just wondering what the factory spec compreshion reading in the manual should be for this moddle brushcutter, im curently overhauling one at the moment that was given to me its had a ruff life you can tell its been used by a council worker or on a farm but surprizeingly the inside of the engine looks alright no scoring or anything apart from a craped out clucth and drum (ha ha ive never seen clucth shoes turn blue from heat under load thats how bad they were) and a muffler so full off carbon it tryed soaking it in oven cleaner,degraser and kero over two weeks it was imposible to save so bougt a newbi and for a brushcutter to show signs of that much use "many thousands of hours or more" and for the internal of the engine still looks good must say something about how well they are made "forgive my raveing its my first stihl and very excited to get it goin" the best ive ever used so far is a makita rst250 from bunnings it ok better than $99 el chepo's
but any guys back to the question im getting 116 psi reading cold
would should it be when its new copard to other trimmers i think it feels a little lite on the pull cord but im yet to romove the jug and decarbon the rings and groves to see if that gives better comp thanks guys apreciated as i have had a hard time finding a manual for this modle but i have found a parts list for free in another langride though but it has full illistraded service diagrams for asembly and breakdown its in pdf here is the link http://rmmaquinas.com/downloads/arquivos/47511dda321b71af5c8c786426c2033f.pdf i hope someone els finds as usefull as i have cheers
steptoe, just put a small spoonful of engine oil in through the spark plug hole and immediately repeat the compression test. If the pressure doesn't increase much, chances are the 116 psi is similar to what it would be with new rings.
The carbon can probably be removed from your old muffler, but since you have a new one now, there isn't much point in trying.
just did that mate even did it twice just to be acurate washed some fuel through in between tests and readins still macth with a small amount of oil like you said my compreshion goes from 116psi to 145psi i will try decarboning the old rings and piston groves then do another test just to make sure they are not sticking and are moveing freely in the groves if not ill have to do rings also "damm" ...
how can you identify if your piston is a genuine oem stihl upon inspection? ...
and do aftermarket piston kits like meteor brand run in stihl oem jugs
18,196 Registered Users
Posts106,846
Members18,197
