0 members (), 4,600 guests, and 1,572 robots.
by nath - 16/10/26 10:48 AM
#2314 18/02/03 01:59 PM
Ok I now have another victa that I have obtained, its not that old, but still has the black carby.
I can start the engine and after about a minute the motor will cut out, kinda like a fuel cut out. I replaced the black plastic carby with a known working carby and still the same problem, which has got me thinking that its not the carby that is the problem. So I ask anyone out there, if they know what else it could be? PS I think its a 125CC motor
ekul
#2315 18/02/03 06:48 PM
Victa Mower Specialist
ekul,
Try replacing the fuel tap.
Victa Man [Linked Image]
Victa Man
#2316 25/02/03 10:04 PM
I did replace the tap already and the same thing happened, i might try it with a fuel tap that i know works
any other suggestions you can think of??
#2317 26/02/03 06:32 PM
Can you check the 'O' ring on the plastic part that the carby connects to as it could damaged from taking carby's on and off. Also check to see that the plastic that is screwed onto the cylinder has a good 'O' ring behind it and is tight.
Good Luck
Victa Man
#2318 27/02/03 07:50 PM
found out the problem, the carby had a crack in it, the hole where the brass screw is screwed in had a crack down it. bought another case for it cost me $33
cheers thanx for your help victa man
mreddie, Matfew, Grahamp, ttvgcm, DeanVR4
18,161 Registered Users
Posts106,819
Members18,161
