3 members (AMP, Adzy, Dandare),
4,690
1,055
Thanks for that Steve. A couple of points you might clarify if you would. First, you use the Lectric Washing Soda as electrolyte in a water bath, for electrolytic cleaning? Second, you use a standard battery charger as the source of electrical polarisation? What kind of battery charger - voltage, current rating, electrical design? What polarity for the part being derusted - positive or negative terminal of charger? How long do you run it for? How do you decide when to stop? Do you remove paint/wire brush the part before electrolysis?
Hi grumpy, thanks for that as well, I was asking myself the same questions, also in the plastic tub there appears to be 2 steel plates wired together; obviously the anode/cathode, but what guage is this? Thanks to Steve for posting the info.
Deejay, I think the two fixed electrodes in the bath are connected together and have the same polarity, which is opposite to that of the part being cleaned. Their gauge doesn't matter unless or until they get eaten through. However there are practical details that are worked out from experience, and Steve obviously has that. I've used this technique years ago to remove rust and metal deposits from the bore of rifle barrels, but that is a specialised process - Steve's is more general.
Thanks Steve, that answers the questions I had thought of. Other members might have their own questions. Guys, if you want to know more about this, I suggest you ask Steve while you can. His restorations are the best I know of, and that kind of expertise is seldom accessible to the rest of us.
thank you grumpy! for your kind reply. to answer the question on paint removal that comes off in the bath/hose off after yep u can have your cup of tea while the hard work is done silently. it is important that the piece is sealed after as it will start to rust instantly the ranex rustbuster works great gloves goggles mask dedicated work area always link to bondall ranex rustbuster with pdf
i saw a really good setup on youtube where the bloke sealed up and used an old chest freezer, his power supply was a 24v one from an old photocopier mounted in a computer case.
Posts106,826
Members18,187
