1 members (morgs), 1,373 guests, and 2,402 robots.
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 24/01/16 02:46 AM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#2158 18/12/00 02:42 PM
A
Anonymous
I have an older Victa (model unknown)I have put new piston & recon. barrel in. Now overheats after 10 - 15 mins. Revs slowly die, becomes noisy & stinky.What have I overlooked?
#2159 23/12/00 02:31 AM
Are you sure you lined up the timing marks when you put the engine back together? sounds as if you are out of time.
Bill Greer
#2160 02/01/01 08:48 PM
Wayne,
The answer to your question would be that you have possibly did not check the ring gap before reassemble. It should be around eight thow gap and when putting the piston in you should have the ring gap facing the exhaust port on a 125cc motor and on a 160cc should be facing the inlet port.
Now the carby valve, the normal setting is 'C' and it should be facing where the cut out is on the carby where it sits.
Fuel mix is 25 to 1 that is 25 parts fuel to 1 part oil or 200ml to 5lts.
Try this and see how you go.
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
fullcranky87, DonD, abigliazzi, I@mthej9, zoist
18,116 Registered Users
Topics12,754
Posts106,797
Members18,117
