0 members (), 784 guests, and 2,329 robots.
Sharing My New Lawn Mower
by ccxue - 21/09/26 07:18 PM
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#20461 12/12/10 04:56 PM
Guys I have a 12/32 Ann. Greenfield ride on. In the cutting plate there are 4 holes and I am running two blades. Can I run four blades. Thanks Dave.
If you have the correct holes for four blades, you can run four blades. That would require a bit more engine power, which you probably have, and might give a slightly finer finish to the lawn or alternatively allow a bit more forward speed for the same finish. On the other hand, when you mess up and hit a water pipe, you'll ruin four blades instead of just two, and you'll have to sharpen and maintain four blades all the time.
I suspect it is mainly a matter of what works for you: how many water pipes do you hit, and how annoyed are you when you have to replace four blades? Four blades would probably lengthen the time between blade re-sharpenings or replacements if you don't hit water pipes.
Thanks for that Grumpy.
Hi Dave,
On the Greenfields, you need the four blades if you are using a grass catcher.
If not, just the two blades are needed.
This is what I was told by my Greenfield dealer.
Cheers, Murray
Ok Murray thanks
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
18,120 Registered Users
Topics12,755
Posts106,798
Members18,121
