0 members (), 1,174 guests, and 4,603 robots.
Deejay, the first step, if there is any corrosion (which mainly means if the key is exposed to oxidation in the outside air, and isn't constantly wet with oil) is to soak it with penetrating oil. Then you need to break it loose, before removing it. These steps are the same as for a Woodruff key, but you break it loose in a different way: you apply a punch to the end of the key and tap it axially to slide it along the keyway. Often the objective is to get one end of the key to lift up in the keyway, so you can lever it out, but if the key is close to the end of the shaft, you may be able to just tap it and slide it off the end of the shaft. In practice you usually can't do this though, because there is a bearing behind the end of the key, right where you want to tap it from, so you are mainly trying to get it to rise up higher in the keyway. Then you can put something under it and lever it up and out.
If the key is right on the end of the shaft and the bearing is close to the key, you can use the bearing's inner ring as a pivot to lift the key. Instead of tapping the key along the keyway, you lower the free end of the punch and tap the end of the key upward. With one end of the key immovable against the inner ring of the bearing, it is usually easy to lift the key in this way. Of course you can use a tiny chisel to get underneath the free end of the key, but this requires lots of tiny chisels of different widths, and often scores the keyway, so it is a bit on the crude side.
Thanks for that grumpy, I have a funny feeling that someone will be looking for this thread when trying to remove a key,and won't be able to find it. Maybe it might be worth while posting both methods in the topic "Restoration, Tips and Queries" and locking it up, mate, What do you think?
Sounds like a good idea Deejay. Would you leave a copy here, or just move this part of the thread? I think I'd do the latter, but you're the communication guru (as well as being much more experienced in how this site works).
Yes grumpy, we would absolutely leave this thread in place, but could you please post both methods as a dedicated thread (such as "Woodruff and Rectangular Key Removal") in the "Restoration, Tips and Queries" topic and lock it up?
It could really come in handy, as it has done in this topic.
Thanks mate,
Done and posted, Deejay. Of course in my usual fashion I waxed loquacious and added some extra detail plus an anecdote.
Repainting the cowl
18,068 Registered Users
Topics12,746
Posts106,766
Members18,069
