0 members (), 2,659 guests, and 1,536 robots.
#19158 05/10/10 02:37 PM
Yes folks I made the first tenative steps in the resto of my sb 45 has begun with the removal of the Kawasaki Fa130d from the frame.In preperation for full strip down and cleaning
Last night I had the chance to take the head offmuch to my surprise (well not) the unit was quite carboned up with the carbon on the piston and on the top of the head being quite wet while the carbon on the spark plug being the normal grey that appears when you are getting full combustion. Another thing that was noticed was that valve clearances were out. More than likely a contributing factor to the carboning up.
As to the Bore It was in excellent condition without a hint of scoring
When the actual oil was drained out properly today a fair bit of sludge came out of the small drain hole. Which I put down to the motor not having been run until I had been given the unit for over 10 years.
So my take is that the engine going to need a strip down anyway
Another job that took place today was the disassembly of the start and the removal of any surface rust ready for repainting.
Wednesday's job will be the removal of the flyweel and the engine side of the clutch cone.
Now I have a few questions.
Does anyone here use caustic baths to clean engine parts up and if so what chemical and strength do they use. Oil sludge is hard to remove at the best of times. ( The only other solution I suppose is to soak the parts in diesel for a few days and then wash in degreaser afterwards)
Bruce do you have a copy of the FA130d in the manuals area?
Cylinder head
Cleaning starter ready for degreasing and repainting.
Surface rust being removed from starter
As far as I can tell from the picture, the amount of carbon build-up is not abnormal, but the softness/wetness of the carbon is. That is usually caused by oil consumption (due to worn rings): the oil does not burn well in the brief time available and carbons up everything, especially the muffler. There is usually some blue smoke if the oil consumption is bad.
If there is an abnormal amount of sludge in the crankcase that is probably caused either by blow-by (leaky rings) or some fault with the breather (crankcase ventilation system). Generally, oil sludge in crankcases is easily washed off by petrol, kerosene or white spirit (white gas, to an American; also known as naptha).
I personally do not use harsh chemicals to clean engine parts (the cleaning agents are prone to being hard to remove, thus causing corrosion/etching later). I don't believe I've ever heard of anyone using caustic chemicals.
Hi Grumpy
Yeah I was thinking of doing the rings regardless of the condition of the bore. With that being said I can now justify the purchase of a Cylinder hone! Which can be used for this as well as my live steam projects! :-) Just need some rich benefactor to provide the capital for a boring head for the mill.
I have watched the oil consumption and it is not using any oil to speak of in the last year. I normally run it for about 10-15 min at a time.
As to the chemicals I think they are used mainly in the auto/truck engine re-con industry.
Greg, because you always need an oversized piston if you bore the cylinder, I think it would be more convenient to just find a better one and install that. Honing can be OK if you do it well enough, and if the bore is scuffed, it is essential. I've literally never used my boring head, for any purpose at all. Shouldn't have bought it I suppose.
I think it is difficult to get to the bottom of your oily combustion chamber without replacing the rings to see if it makes a difference. I'd check the breather, and if it's OK, try to compare the amount of crankcase sludge with other similar engines. Has the engine been over-filled with oil?
user degreaser then kerosene to clean up the engine parts
Yeah I have used petrol for this purpose before I was just trying to think outside the square
To Grumpy. This weekend I am finishing the striping down of the motor. I intend to soak all the parts in petrol for a day or two and then degrease for final cleaning. As to the breather I think that looks like being a problem due to the amount of crud in that area. All I need to purchase is a 6" gear puller as the flyweel does not want to budge.
Are you sure it is supposed to be pulled from the outside diameter? That method is a bit unusual, because it is prone to bending flywheels. The B&S flywheels are pulled with a small flat-plate puller that attaches via three small tapped holes near the center of the flywheel. Flat plate pullers pull very strongly without damaging the parts.
Normally I would be with you but the Kawasaki Flywheel does not have any facility to install a flat plate puller. And is made of cast iron to boot to make things more interesting.
I've checked the service manuals area of this site and have not found anything on Kawasaki. Getting hold of a repair manual for your engine would be a good move at this point.
pics of the flywheel before you go crazy trying to remove it
Ok After a day soaking with WD40 it came off easily with a tap of a rubber mallet.
Update
The motor has been cleaned in petrol and light pitting was found on both the intake and exhaust valve seats. Re-lapped valves/valve seats with valve grinding paste to remove pitting.
As I recall that is a side valve engine so you will probably need to grind the valve stems to restore the correct tappet clearance. (Lapping valves reduces the clearance).
Grumpy is correct with needing to grind the valve stems to give the correct clearance, this can be done very crudely with a grinder if you are careful however with a nice motor such as the kawasaki I would be wanting it done properly on a bench machine.
Cheers Joe.
That's good advice there Joe, there is no substitute for good workshop practice, especially during a restoration...I remember a very wise old mechanic told me "Do it once and Do it right"... wink
Do it with Fibre???
Latest progress in pictures. After lapping and cleaning I put the cam shaft in to give the valves a run and they are now spinning where before they were not. One thing that is interesting is the piston ring arrangement is that after cleaning I found that one of the rings is actually stepped(mmm interesting
Cleaned crank case
Be sure to put the rings (old or new) on the correct way up.
Hi all
The piston is now back in the block and bolted back on to the crank as well as new valves having being installed. Valve clearances were within spec.
I have found a manual for the 130D at amazon
Small engine manual
Hi Greg, Its great to hear that it's all going well for you, please don't forget to post pics as you go along, as we all love to see them. wink
Tonights work involved installing the new Carbie gaskets and filter and cutting up the foam for the new air filter.
Here is some pics of the nights activities [Linked Image]
Here is some other pics from [Linked Image]
Update:
The ignition timing has now been done and the engine has been re-assembled. The spark is now a strong blue colour compared to the weak yellow colour that I had before the strip down which is now generated at a lot lower rpm than what was before. When looking at the electrical components I had found that the ignition lead had Sumitomo 1981 printed on it which means that it was a fair bet that the motor was made that year.
I have a question on the removal of the drive shaft key on the sprocket end. What methods have members on the group tried to get this key out. As I am wanting to repaint the drive shaft to be similar to what Deejays is but in black to match the FA130d starter.
Thanks in advance
-greg
The first question is whether it is a rectangular key or a Woodruff (half-moon) key. You use different methods for the two types.
Hi Greg, the key is a half-moon type, just give the area a good soaking with WD40 or CRC, grab a screw driver and hammer; now locate the tip of the blade low down on one end of the key and tap gently...it should slide up and out. wink
Been trying to do that all day yesterday with that woodruff key ! ;-) lol
I agree approximately with Deejay's prescription for removing a Woodruff key, but I always rock them first. That is, I tap downward, toward the center of the shaft, on one end of the key until it tilts. Then the adhesion between the shaft and key has been broken. I then tap longitudinally on the end of the key that is now raised well above the shaft, due to the tilting of the key. That is the right way to remove a Woodruff key, and the wrong way to remove a rectangular key, so you need to know which kind you have. Thanks Deejay.
Hi grumpy, now you've tweaked my interest mate, what is the correct method of removing a rectangular key?
18,085 Registered Users
Topics12,748
Posts106,774
Members18,086
