2 members (Murpha, Dandare),
1,820
672
Gday
I put all the shafts in correctly, and I lubed them up well. The chains are installed and I put the wheels on, but when I engage the clutch the wheels lock up. I noticed when I moved the lever the whole body of the rotary hoe slid left on the axle. How do I stop this and get the clutch to fully engage? From what I make of it, it seems the sliding axle shaft is the problem.
Matty
Posts: 5,395 Likes: 35
dim03, The shaft on the axle should not move at all if you have installed it correctly. The dog clutch is the only thing that should slide.
Turns out I forgot to install the end bearing locks... oops.
dimo3,
I have now closed this topic as it appears you have fixed your machine.
Topics13,058
Posts107,236
Members17,806
