2 members (aitchey, Gizmo), 5,510 guests, and 1,870 robots.
robj #16576 08/03/10 08:11 PM
hi bruce,
original i joined the forum to acquire this one manual, which i never did ! i cant sem to locate it in the manuals area. whas it ever uploaded?
thanks allot
regards jay
mowernut #16580 09/03/10 01:31 AM
Jay,
The parts list is the 2nd attachment and under parts list and manuals are for ride on mowers (sub forum).
Click HERE to go to the section. cheers2
Bruce #16586 09/03/10 08:45 AM
thanks bruce!
i have turned one of these into a go cart for all the 100's of kids that seem to congregate around our place, but want to re attach a deck and decent engine to make something of it. do you know weather there are cast iron flywheels available for the late model briggs quantrum engines? it is running one with a aluminium one but it bites when you go to pull the rope.
regards jay
mowernut #16588 09/03/10 09:10 AM
Sounds like an ignition timing error.
grumpy #16590 09/03/10 10:26 AM
G'day,
yeh ide agree accept ive alredy checked the flywheel key and made sure the magnetron is at the right distance from the flywheel. i believe the problem is that the pressed steel stack pulley is way to light to act in place of the blades as a flywheel apparatus. the original engine was one of the good old 5hp briggs i/c with the big very heavy cast iron flywheel. the thing about the kickback is when it gets to the compression stroke it kicks because there isn't enough momentum stored in the light flywheel to spin it easily threw the compression stroke.
regards jay
mowernut #16592 09/03/10 10:51 AM
Jay,
Are the pulleys heavier than the flywheel? cheers2
Bruce #16595 09/03/10 01:04 PM
G'day,
you mean the stack pully? no it is not. the old cast iron flywheels are about 3kg wear as the aluminium ones are about 500 gms and the stack pulley is about 400gms.
i dont really want to spend any money one one but if anyone has the appropriate cast iron flywheel for a 6hp briggs quantum please let me know.
thanks
regards jay
mowernut #16598 09/03/10 01:17 PM
I acknowledge that it may be a flywheel issue, if you are trying to run it with a light flywheel and with no drive to the blade plates. B&S warn us against doing that, and it seems the obvious cause of the problem you are having. Is it the wrong engine for the mower (i.e. one that is made for a direct drive push-type mower, and hence has a light flywheel, but you are running it on a ride-on, which starts with the blade plates declutched)?
grumpy #16608 10/03/10 10:03 AM
hi all,
your spot on grumpy, the engine came of a mtd 18" mower with a standard bar blade. it was all i had at the time to put on there, and has lasted well, considering its a bunch of 10 year olds with the foot flat to the floor and doing donuts donuts while riding it. the engine on it needs to make way for either a identical rebuilt quantum or a barstidised ohv briggs when i attach the deck. i dont really want to put the new engine on it till i find out if i can put a decent flywheel on it or not. i dont want to spend too much though.
thanks allot
regards jay
18,147 Registered Users
Members18,148
