2 members (AliPike, MowingManiac), 2,763 guests, and 238 robots.
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
by NormK - 22/02/26 02:31 PM
by Bruce - 20/02/26 12:02 AM
#15854 21/01/10 04:19 AM
What fuel do you use in your Briggs and Stratton?
Cheers.
I use ordinary unleaded. There are advantages in not using any fuel containing ethanol, because it might shorten the life of some elastomers in the fuel system.
My old 1963 Briggs had a label on it saying 'Use only standard petrol', which was fitted by Alroh in response to Briggs saying use only standard-grade gasoline. The advice made sense in the US, where it was the practice to produce super-grade petrol by adding extra tetra-ethyl lead, and the lead tended to gum up the spark plug, exhaust valve and muffler. However it was pointless in Australia where the practice was to produce standard and super petrol in the refinery from different constituents, then add the same amount of TEL to each (more or less the maximum amount allowed by law.) The older Briggs engines have very low compression ratios and can run on very low-octane petrol. Not so sure about the current OHV engines, but standard unleaded (91 octane) will exceed their requirements.
Thanks for that, so no lube required then.
You do not need to add oil to the fuel of any engine that has an oil sump lubrication system. I've heard rumours of B&S crankcase-induction 2-strokes made many years ago, but I've never seen one. Normal B&S engines are all sump-lubrication 4-strokes. Putting additives in the petrol of such engines is even sillier than putting them into the petrol (or oil) for your car.
sweet, thanks grumpy.
17,872 Registered Users
Topics13,071
Posts107,310
Members17,873
PHP: 8.3.30 Page Time: 0.092s Queries: 25 (0.087s) Memory: 0.6357 MB (Peak: 0.6677 MB) Data Comp: Zlib Server Time: 2026-03-11 10:06:08 UTC
