Thanks Bruce, Thanks Bruce. Have just taken off the cowling only to find someone has had a cold chisel to the nut not much left of nut ,is the nut part of the starter cup? its a 160 with a green body the only reason i may have to get it off is that it caught fire the other day i had just primed it and pulled the pull starter only to get a spark jump down to the body where a lot of dust had garthed and was a bit oily so when i primed it the excees of primer petrol went on dust etc and caught fire,so i may need to replace spark lead from inside under flywheel unless i mght have to replace the whole assembly,graham
All the parts that you might be looking for are in the online shop just click HERE but you will have to register in order to purchase as it it not part of the forum.
The starter cup is usually separate to the nut unless the mower is a very old type, if you can post a picture it would help.
Hi Bruce Got the old girl going again apart from a few burns after the fire ,shorten the fuel lead and she fired up,have attached a couple of photos of mower and flywheek nut, Can not figure out how to send the photos its a bit hard to figure out. graham
