2 members (Red Rum, MarkusB), 8,844 guests, and 645 robots.
#122503 12/09/26 03:12 PM
FiM
Offline
Hey I resently got an old rotary hoe with a briggs and stratton 5hp it had a few problem but iv got new carbi new exhaust new head gasket seal new electric starter motor but it starts and then sckwheels loudly and melted plastic pull cord assemble and pushed all the cord back out and the ratchet washer melted off so I replaced both started it again and same thing what going on please any help would be super appreciated
FiM #122505 12/09/26 07:30 PM
Hi FiM
Not completely sure what motor you have without seeing it but sounds like the one with those older Briggs recoil setups, that the clutch pawl or ratchet sprocket acts up, works just like a bicycle freehub—if the little dogs or springs get gummed up, worn, or fail to disengage, the spinning flywheel catches the starter and forces the cord back out at a million miles an hour, generating enough friction to melt the plastic housing and fry the ratchet.
You can buy a new inner starter part that threads onto the crank, if you can find one, but usually these have small steel balls inside to
engage ,if its not too stuffed I usually open the seal up enough with a feeler gauge on the ratchet part and spray WD40 into it , you aren't
meant to as this makes it slip but if you spray it then leave it a day its usually dries enough to work but is lubricated enough to stop the squealing
and ripping the rope starter apart.
I usually find if I replace them with another second hand one it does the same thing until you use WD40 in it.
1 member likes this: FiM
FiM #122506 12/09/26 08:48 PM
If all else fails bring it to my place and I can fit a later cup starter setup on it seeing you are in Melb
18,242 Registered Users
Topics12,778
Posts106,883
Members18,243
