0 members (), 9,553 guests, and 1,339 robots.
Hi, I recently picked up what I believe to be a Scott Bonnar model 33 lawnmower off the side of the road during a council rubbish collecfion.
I have absolutely zero mechanical knowledge currently but would like to restore it back to its former glory before using it to cut my lawn. Based on reading some posts here I believe it to be a mark 2 model as it has a belt and chain configuration.
The original engine I believe has been replaced with a briggs and stratton 475 series 148cc. It also has a Rover speed control switch. I will try to upload some pictures.
Although I haven't tried starting it yet, apart from the odd dents and scratches the mower seems to be in good condition for its age, except for a random bit of wire sticking out from the front of the engine.
My question is, what's the wire sticking out from the engine and where should I start in a restoration process from a complete novice prospective, I assume rust and dent removal would be the first steps before trying the mechanical side of things.
Kind regards
Mike
Hi Mike33,
That wire as shown in the parts list below it is the stop wire but you don't need to connect it as the throttle control on the motor has the stop connector there.
Model 093312-1155-B1 Parts List
1 member likes this: Mike33
G'day Mike
Take lots of photos of the mower from all angles.
Identify missing, broken, or seized parts.
Make a list of what you need to replace or repair (nuts, bolts, bearings, paint, blades, etc.).
Check for historical manuals or diagrams online
This gives you a clear idea of scope — saves frustration later.
2️⃣ Clean and Degrease
Even before sanding or dent repair, give it a good clean:
Remove loose dirt, grass, and grease.
Use degreaser on the reel, gearbox, and handles.
Avoid soaking bearings and shafts yet — just clean the surfaces.
Pro tip: Cleaning now helps you see rust, dents, and cracks better.
3️⃣ Disassembly
Take the mower apart carefully.
Label each part or use ziplock bags for small screws/bolts.
Take more photos during disassembly — very helpful when reassembling.
Order tip for novices:
Remove handles and frame panels
Remove cutting reel and bed knife
Remove gearbox, wheels, and axle assemblies
Don’t force stuck parts — penetrating oil can help.
4️⃣ Cosmetic Work (Rust & Dents)
Yes, generally cosmetic first:
Rust Removal:
Light surface rust: wire brush, steel wool, or sandpaper.
Heavier rust: naval jelly, vinegar soak, or a wire-wheel attachment.
Powder-coated or painted surfaces: consider stripping old paint first (chemical stripper or sandblasting).
Dent Repair:
Small dents: hammer + dolly or soft mallet.
Big dents: consider body filler if it’s on painted panels (not critical for mechanical function).
Final Prep:
Sand all surfaces to smooth metal.
Wipe down with solvent before painting.
5️⃣ Mechanical Inspection
Once the cosmetic surfaces are sorted:
Check the reel bearings, wheel bearings, and gearbox.
Spin the reel by hand — is it tight or binding?
Inspect blade tips and bed knife. They can often be sharpened rather than replaced.
Grease and oil moving parts.
Replace any missing fasteners.
Pro tip: This is easier after paint is cured to avoid scratching new surfaces.
6️⃣ Painting / Finishing
Mask off mechanical parts like bearings, gears, and blade edges.
Primer → Paint → Clear coat if desired.
Let paint cure fully before reassembly.
7️⃣ Reassembly
Follow photos and part labels.
Lubricate moving parts as you go.
Adjust reel-to-bed knife clearance (Scott Bonnar mowers are famous for needing careful adjustment).
Test-roll the mower before using it on grass.
8️⃣ Testing
Start with a small patch of grass.
Check for:
Smooth reel rotation
Proper cut height
No unusual vibrations or squeaks
Take your time.
Use YouTube or mower forums for visual guidance — there are Scott Bonnar enthusiasts with step-by-step videos.
Document everything — even small steps help during reassembly.
If something looks rusty but structurally sound, you can sometimes clean, prime, and paint rather than replace.
2 members like this: Mike33, mice_elf
Thank you Max for the detailed reply, I'm sure I can use the same steps for other repairs / restorations.
Kind regards
Mike
Hi Bruce
Thank you for clearing that up as I was wondering if something was disconnected internally or missing completely.
Kind regards
Mike
SantaAnaWinds, JinxJuno, Kenniffs, Neill M, Peenuke1
18,243 Registered Users
Topics12,778
Posts106,883
Members18,244
