1 members (looktall), 6,238 guests, and 1,615 robots.
by Bruce - 01/11/26 10:58 PM
#12118 10/05/09 10:34 AM
Can you tell me if the nut that holds clutch on my Titan 57 is left or right hand thread. Also any ideas on what I should check as the auto chain oiler is not working. Thanks in advance.
nardi,
Usually the nut will tighten up when the motor is running so if the motor turning clockwise then the thread would be left hand. cheers2
The problems I have had with chain oilers were usually either lack of supply, loss of pump prime, or partly blocked outlet. The lack of supply happens either because the pick-up filter in the oil tank is blocked by crud, or the rubber hose inside the tank between the pickup filter and the pump intake has split and it is sucking air into the pump. The loss of pump prime happens because somebody has used dirty oil (in my case a friend had used old sump oil for chain lube) and scored the oil pump piston and bore so it had difficulty priming itself after it had been run dry. Once it primed, it worked OK despite the damaged pump. The partly blocked outlet happens from wood chips getting into the nozzle that squirts oil onto the chain. Crude cleanout techniques compound the problem by damaging the nozzle, and you end up with oil going everywhere but onto the chain.
Moderated by  Bruce, Mr Davis
18,199 Registered Users
Topics12,769
Posts106,848
Members18,200
