0 members (), 918 guests, and 1,056 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Hi VM,
You could go with that button guard but the missile / Nitrous oxide switch cover looks way cooler. cool
There must be something I am not understanding with this whole saga?
Senior Contributor
Thanks Max,
Yeah they sell them as missile trigger guards. Haha! Couldn't find one to fit my switch is the problem.
Norm, I've decided to add a small motorbike battery now that I have found a place to locate one. The return cover is just the easiest way to prevent yourself from bumping the starter button while maneuvering about bushes, that's all.
I have used small motorcycle batteries on them no problems vint_mow, had another one come today $45 pretty good value. I still think you are worrying too much about hitting the starter button, the plastic starter gears are worth peanuts and that is all that would get damaged and you would have to bump it a hundred times to do any damage. The gears are probably a lot cheaper than the switch you just bought
Hi Norm what Amp Hour batteries are you using ,I assume a 9 AH ,a long time ago when I bought batteries for mowers ,I'd buy a small
car battery because I could buy them cheaper than a motorbike battery.
Yes Max the 9amp hour the gel ones seem to spin them over okay
Ok thanks Norm they look a good battery for the price.
Last Sunday I picked up an electric start mower 248cc motor on the roadside and pushed the starter button and it fired up straight away
I didn't even need to put fuel in the tank.
Good pick up that one Max, you seem to pick up a lot of good stuff out your way
Yes you can find good stuff Norm but you can't sell it as most people just buy new.
Yes Max,
It is the way of the world people either want it for nothing or they go and buy cheap Chinese stuff and throw it away when a wheel falls off. Replacing a wheel sounds simple to us but if you can't repair it and have to take it to a mower shop it is often going to cost more than a replacement item (or heading that way). Some of the repairs you see on some of this equipment make you look at it in disbelief but if your skill level is duct tape then I guess this is why things that to us are an easy fix, but to other people all they can do is replace it
Senior Contributor
Norm, One of the funniest attempts at fixing a mower was on a 70s Rover I picked up at the local tip shop a few years ago. Someone obviously must have had trouble starting it, so they had stretched out the spring on the carby about 20cm and had it fastened to the back of the cowl with a screw. I'm not sure what they hoped to achieve by this. I can only guess it was done out of sheer frustration. The reason why the mower would not go should have been obvious. The tank and carby were full of gunk. I flushed everything out and replaced the carby spring, put in some new fuel and oil, gave it a pull and it ran like a new machine.
A friend was telling me about a whipper snipper at a tip shop. Someone had brought it in because it wouldn't go. The first thing he noticed was the spark plug lead was not connected. He puts the lead back on the plug, gives it one pull and away it goes. Hard to believe, but someone had actually taken this brand new Stihl whipper snipper to the tip because they did not realize that a spark is needed to make an engine run!
The long line up of Chinese mowers at our local tip is a good case in point. Clearly the motors are the main issue, as the bodies still always look good. In fact some of the machines could be mistaken for being brand new. They stop and people just take them to the dump and go out and buy a new one. It is a sad indictment on our modern throwaway lifestyle which must soon come to an end.
As for batteries I ended up going for a highly dangerous Lithium battery. I made sure to also buy a flame-proof bag to charge and store it in and got one that has a trickle charger. Apparently it is the "fast charge" ones that are dangerous. They charge too fast ad overheat. It is amazing how much power can be locked inside one of these tiny batteries that could almost fit in your pocket.
vint_mow, all you need for the battery is a tiny 12 volt trickle charger which you can leave on charge all the time. That way everytime you go to use it it is fully charged, ready to go
Yes I get tired of seeing all the mowers Norm and Vm that have duct tape holding the handle bars together where
they fold in half because they have lost the bolt or nut ,I've seen a lot of knives , forks, spanners and screwdrivers stuck to broken handle bars with sticky tape to hold them together.
Senior Contributor
My gripe with dodgy online sales continues. Thought I might save myself a buck on making up a battery holder to secure to the frame. Bought a small steel billet to hold the battery, only to find it is about a mm too small for the battery. Very roughly made too. The welding must have been done by Captain Jack Sparrow using a coconut for a set square. Nothing about the thing is square. Essentially just metal folded around a few times, spot welded, then two fasteners attached on a skew. The spot welds on the top will probably break due to vibration in a short time. It is advertised as a universal fit for motorbike batteries but it is a mm shy of fitting mine. Looks like I will have to make one after all!
Senior Contributor
Slightly off topic here, but this Rover is not one that I am familiar with at all. It was found on a UK website. I can only guess they were released in the UK and not here? Bit of a mystery to me this one. Can anyone tell me anything about it, like model, year made etc.? It is like a re-modelled version of the popular Heavy Duty Australian one. The red paint could put it in Rover's "red" period, so probably 1980s/90s, maybe as late as about 2013. Would the OHV be the original engine I wonder?
With the battery tray Vm I would just cut a bit of wood a couple mm bigger than the battery tray and hammer it in then drill the wood out.
Senior Contributor
Probably bust the spot weld, but I guess it is worth a try. Obviously a very snug fit is what they were aiming for.
Senior Contributor
Has been answered here: Rover flail mower
17,714 Registered Users
Topics13,031
Posts107,112
Members17,715
PHP: 8.3.27 Page Time: 0.069s Queries: 54 (0.060s) Memory: 0.7176 MB (Peak: 0.8274 MB) Data Comp: Zlib Server Time: 2025-12-10 16:17:59 UTC
