2 members (Dandare, MaxyP), 1,019 guests, and 2,312 robots.
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by MowingManiac - 19/02/26 08:57 PM
by Bibi38 - 26/09/26 10:20 PM
by Bibi38 - 26/09/26 10:00 PM
by NormK - 26/09/26 09:24 AM
by anna23 - 25/09/26 10:38 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
NormK #120599 10/01/25 08:32 PM
I'm getting to the stage with these E/S Deutschers that it might be easier to just have them on $10 trickle charger all the time because how many times a year are they going to be used for cleaning up around under the fruit trees? Probably 3 times a year which means the battery will probably go flat between mows
NormK #120605 11/01/25 03:32 PM
I was thinking a while ago if you used a solar panel and charge controller there would be no need for the engine to charge the battery.
A smart charger/battery maintainer would be better if leaving the battery charger plugged into mains power.
I guess a Power Point Timer may also work with the trickle charger so the battery isn't over charged.
NormK #120606 11/01/25 04:24 PM
Hi Max,
I have a 12 volt system running through my house, it powers the smoke detectors the CO2 monitors, kitchen clock, street number out the front, light at the front door and a 12 volt pump in the garage downstairs as a back up if we loose power here and a high water alarm in the sump pit which alarms if the 12 volt pump activates. I have a battery each end of the house and they are on constant trickle charge, battery maintainer and have been for years now. The only time I had trouble with a battery overcharging was when I got smart and hooked it up to a solar panel. It worked fine until the controller stuffed up and cooked one of the batteries. That battery is still connected and works fine just powering my system but if I put any load on it it falls over. Anyway these little trickle chargers don't seem to overcharge the battery. I think they put out 1000 milliamps, which is probably what a battery looses just sitting these
NormK #120621 13/01/25 05:02 PM
So you just use a charger like the one below to maintain the batteries ,I need to get something to maintain a battery just not
sure if to go solar or electric plug in.
I have heard some of the small solar charger panels only last 4 years.
NormK #120627 15/01/25 09:28 AM
Hi Max,
I am using these chargers, have been using them for years with no problem. I have 5 of them hooked up running 24 hours a day with no issues at all and they use virtually no power at all and I monitor my power daily. The solar panel I set up was only a cheap Chinese thing and it only lasted probably 18 months before it went haywire and cooked the battery.
https://www.ebay.com.au/itm/294640723981?_
NormK #120635 15/01/25 05:35 PM
G'day Norm,
Thanks for the link ,found one that looks the same under $2. with free shipping but most likely will get the eBay one.
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
Bushmechanic, Eltenj, Murray K L, Bibi38, anna23
18,129 Registered Users
Topics12,754
Posts106,802
Members18,130
