3 members (BobsYourUncle, watto123e4rtyu, bmba2), 7,635 guests, and 511 robots.
#120350 20/12/24 09:47 AM
Does anybody know how to remove this centre cap that is holding the screen on. I guess it must lever off but I don't want to damage it if I can avoid it
I haven't removed one from this type of briggs motor but the 17.5 hp is just a press fit and I can see 2 indentations so
I would just use a flathead screwdriver or a small pry tool to gently pry up on one edge of the cap then the other side
so it's removed eavenly
Thanks Max, I figured that probably was the case just wanted to check
Yes it just pries up with a flat head screwdriver and then you have access the screw underneath it holding the flywheel on.
Thanks AVB, was so simple I should have tried to lift it but didn't want to bend the screen as I had paid $50 for this motor with a broken con rod. I needed the air filter cover because my wife had thrown the one I had in the rubbish bin. Anyway I got a good starter, carby, stator, flywheel the top cover and $5 scrap for the motor so I am happy
18,172 Registered Users
Posts106,820
Members18,173
