0 members (), 3,861 guests, and 460 robots.
Dear Folks
I have got almost new pressure washer with Honda engine GX390 bought 2020 used only 4 times
The carburetor was clogged because I forgot fuel inside the tank and it wasn't starting hence I cleaned the carburetor now it is running fine but only when the choke lever on half open position (closed position)
Please see the attached video :
https://imgur.com/a/LHPBZeG
Thx
Hi zillh,
Has the carby been completely dismantled and cleaned (main jet and emulsion tube taken out ,removed
the low speed jet. on the top of the carby , it's beneath the black cap.)
Fuel tap needs to be removed and cleaned ,check fuel flow with the fuel bowl removed ,clean needle and seat
orifice.
You may need an ultrasonic cleaner but occasionally they still won't clean out and you can just buy
a replacement carby for $17. with free postage.
Thx Max for your help
I will check the video again
If you don't have a ultrasonic cleaner zillh, you can try boiling the carby to clean it .
18,177 Registered Users
Posts106,821
Members18,177
