1 members (mrkhemlani), 1,089 guests, and 240 robots.
by Ghost - 25/10/25 07:11 AM
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
by NormK - 25/10/25 09:57 AM
by NormK - 22/10/25 09:06 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
Rotomo crank shaft
#119664 08/08/24 03:46 PM
Does anybody know the thread size on the bolts that hold the coil down on the B&S motors. I need a tap to thread the holes to mount a stator on an 11 hp Briggs. The mounting towers are there they just need to be threaded
NormK #119665 08/08/24 06:34 PM
I had a look at a 10 /11 hp briggs and the stator bolt is the same as the bolt that holds the coil.
I don't have a thread gauge that goes that fine ,best guess is it's 5/32 bolt 32 TPI
and (1 inch long measured under the head to end)
Usually if I'm not 100 percent sure I'd buy a bolt that size and try it and if it's right
buy the tap.
NormK #119666 08/08/24 07:02 PM
I read somewhere it was 8/32 but my son pointed out that should be 1/4 inch. I ended up tapping them 4mm I don't care if it is not authentic, somebody else can worry about it
NormK #119667 09/08/24 06:10 PM
Ok now I have another question due to my son doing things he shouldn't touch he has damaged the thread in the top of this crank and I am going to need a tap to clean up the thread. The motor is a 10HP Briggs Does anybody know what thread it is. I measure it as 9/16x18 tpi but would like to know for sure as these taps are expensive
NormK #119668 12/08/24 12:03 AM
Norm in order to even try look up thread sizes I need to know the model and type numbers. Some are SAE and others are Metric. Just when and where the engine was made.
NormK #119669 12/08/24 01:40 AM
The motor I have here Norm has a male thread at the top of the crank which is 5/8 and 18tpi , I'll have a look tomorrow if I have one with a bolt hole in the top of the crank.
NormK #119670 12/08/24 04:07 PM
Thanks AVB and Max
, I'm fairly comfortable it is 9/16 x18 tpi, a mate has a tap so I will see how it goes, at least I don't have to buy one
NormK #119678 18/08/24 06:26 PM
I got a 9/16th x 18 TPI tap and cleaned the thread up and all fixed up , another get out of jail problem solved
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Muntz, Dragos, fordy, Mikey.Menace, Maudebs
17,644 Registered Users
Topics13,011
Posts106,980
Members17,645
PHP: 8.3.26 Page Time: 0.021s Queries: 31 (0.015s) Memory: 0.6520 MB (Peak: 0.6970 MB) Data Comp: Zlib Server Time: 2025-10-29 05:48:34 UTC
