0 members (), 9,553 guests, and 1,339 robots.
#119202 09/01/24 06:53 PM
Gday guys,
Wondering if this is a simple fix.
My Masport olympic 660 has started breaking the chain link on the reel chain. Has happened 3 times in the last month. Any idea as to why this would be happening??
Hi Butchy, that has hit something
1 member likes this: Butchy8
Originally Posted by Butchy8
Gday guys,
Here is some information that might help.
Masport Technical Bulletin 400-500-and 660 models
Hi Butchy , Norm and Bruce,
As Norm said the wear on the end of the joiner link looks like it was rubbing ,you could try putting the link around the other way
so the clip is on the other side also the clip must be installed for the correct Direction Of Rotation. (your joiner link needs replacing)
I would also check the sprockets aren't warped ,bent or damaged and are not out of round with high spots also check the teeth aren't twisted ,bent or damaged .
Check any chain guides aren't excessively worn and the chain is not twisted and check the bearings aren't excessively worn and there
is not excessive backlash on the sprocket shafts.
SantaAnaWinds, JinxJuno, Kenniffs, Neill M, Peenuke1
18,243 Registered Users
Topics12,778
Posts106,883
Members18,244
