0 members (), 1,571 guests, and 2,170 robots.
Yes there are a few ways to check for leaks without doing a Vac or pressure test and I'm sure you've done these tests below.
You get different results depending on how bad the seals are leaking ,sometimes I just put about 10 squirts of oil into the
spark plug hole then put the plug back in ,then turn the motor over a few times ,after you let the mower sit for
a couple days you can see oil running down the crankshaft.
If you know the carby is good but the motor is running too fast you know there has to be air leaking into the
motor also when a motor runs and you turn the fuel tap off and the motor revs up before cutting out.
Sliding a 1 to 2 thou feeler gauge between the crank and the seal will be a loose fit when the seals are worn and hardened from age.
You can start a 2 stroke then spray starter fluid at the seal and if the revs change the seal is leaking.
I've had a few 2 strokes that will only rev out if you almost completely crush the snorkel tube when running ,must
be giving the engine more fuel to compensate for the extra air leaking into the engine.
Automotive seals generally stay soft for about 10 years,so as we know the seals are fairly suspect on old mowers etc.
max.
1 member likes this: AussieHJ
Good afternoon all, life got in the way and got back to this last weekend.
I purchased a known good second hand coil, points, condenser and fitted these, and an all-metal G3 carby that was also known good and cleaned/seals replaced.
Second pull she fired and 3rd pull she started.
150 square metres of mowing later, I think we can safely say she's running!
Reel and bottom blade could obviously use a grind, I think the drive clutch cable needs replacement and the cut isn't 'square' but surprisingly good for a machine I don't expect has mown for the best part of 10 years!
My lawn has been neglected too over the last 6 months and isn't the best canvas to work with...
I don't suppose anyone knows who would do a reel sharpen/grind in the Wagga area?
Very good well done looks good
BeardedBiker55, odkmower, luddite dave 01, Flanderino, 4x4stretch
18,069 Registered Users
Topics12,747
Posts106,768
Members18,070
