0 members (), 3,683 guests, and 518 robots.
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
by NormK - 17/10/25 08:56 PM
Rotomo crank shaft
NormK #120261 13/12/24 08:47 AM
Originally Posted by NormK
Hi Nick
The issue is well known to Briggs, the cam valve lifter fails and then you can't turn them over because you are hitting full compression too early. They have been known to fail after only 20 hours use and the Briggs fix it to replace it with a new cam that could fail again in another 20 hours. Good for the dealers but Briggs don't care about the customer, they can pay the bill
As an owner of one of these engines, thank you for flagging this.
Is there anything one can do to minimise the chances of this fault occurring? Or do you think it's better to do something like the Victa decomp valve if/when it happens? As I have to say I've found it an excellent engine in my limited usage of it. Good power, easy to start, pretty frugal on the fuel etc.
Thanks in advance
NormK #120263 13/12/24 02:33 PM
Hi Nick keep going with it the way it is, only worry about fitting a decomp if the need arises. I still can't pull start these machines but that is because I have no strength left. With the E/S they spin over easily, but fitting the E/S and all the little bits needed to make it work is a big job and not one I would suggest anybody try
1 member likes this: N1KK0
NormK #120269 13/12/24 05:52 PM
Ah I'm sure you're underselling yourself & your prowess, like the true gent you are!
Oh well that answered my next question which was how in blazes you fitted them in the first place - so "With a LOT of trouble!" does make sense. :-)
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
yaapeet30, immi1974uk, Dingo1985, RyanONeil, donk65
17,636 Registered Users
Topics13,009
Posts106,964
Members17,637
PHP: 8.3.25 Page Time: 0.027s Queries: 21 (0.023s) Memory: 0.6340 MB (Peak: 0.6567 MB) Data Comp: Zlib Server Time: 2025-10-20 12:26:09 UTC
