1 members (Peter Gilligan), 7,678 guests, and 298 robots.
#118796 12/09/23 06:27 PM
Found this on the kerb last week. Yet to assess the motor on this Morrison 460 but the body and blades ate in good shape. Came with catcher.
Hi MF,
good find, muffler looks to be on a bit of an angle?
Originally Posted by NormK
Hi MF,
Hi NormK,
Don't think so after taking a look. I've been told by a guy who looks for mowers that he's coming across far less of these Briggs than before, mainly finding Chondas now, so I was extra thrilled to get this.
I used the hot staple set you put me onto to fix the corner of this VC Mustang catcher I found up the road.
Thanks again for sending me the link to this item on EBay.
Hi MF,
those staplers are very good I use mine quite a bit and they do make the join good and strong
Hi MF,
You're not wrong NK. I even used it to mend a broken handle on the bin. It's been months and as solid as ever.
PS it looks 1000% better than getting patched up with metal and pop rivets.
A 450 is good? I acquired this one a couple of years ago, used a few times and it failed to start (I never knew the correct starting procedure).
Whist messing with it the plastic bit of the cable control fell to bits...it's sitting on top of the mower. Is it worth fixing, it ran well.
Danny
Hi Danny,
Nothing special about the Briggs mower, not too bad, all depends if it runs or not. Usually the reason the throttle breaks is because the cable has rusted up and people force the throttle control and it breaks inside.
MF,
I also have to repair our rubbish bit, it has a split in the side, obviously caused by me putting too much weight in it, but it is a rubbish bin and I put rubbish in it. I consider broken bricks and concrete to be rubbish
They're easy to work on and are an old well proven design perfectly suited to domestic duties.
MF,
I personally wouldn't be filling them with heavy items like bricks, rocks and concrete. Maybe a small amount.
I've had a green waste wheelie bin rejected because it was weighed down with a high amount of soil.
I don't think they were designed to be filled to the gun whales with such densely heavy rubbish like concrete metal etc.
Main thing with these ones is check the rear splitter bar is in place near the front axle (its riveted on) they are often snapped off and without it the frame flexes - first it cracks near the top of the catcher chute, then down near the rear left wheel.
In extreme cases the whole lhs rear axle pulls clean through the body through metal fatigue
If it has a 4 blade disc, remove and check for cracks around the centre bolt - they were recalled for this about 10yrs ago but plenty still out there.
70kg is max for most bins. the bins can take probably 150kg but the arm on the truck wont.
Thanks for your valuable info as always Tyler.
I'll take a look when I get the chance. It is a two blade model and they're in good shape.
NormK, could you give your opinion on what I should do (or not) with this repair on the rear of the 1970s VC/Mustang/Sport catcher? Remove the rivets and staple or just leave alone? I'm favouring the latter.
Hi MF,
I would see if I could get the faces flat and then put a few staples in it just to tidy it up a bit
Hi MF,
Hi NormK,
Thanks for that. Problem is the patch itself looks to be holding it apart as it wasn't put on with care.
I can staple parts of it. Maybe I'll see after that.
Made the mistake of drilling the rivet with a drill bit size too much. Otherwise an improvement.
Hi MF,
bit of filler or JB Weld in the holes and give the area a bit of a sand back and it will look pretty good. The rivets always look like that is the best I could do, and probably was in years gone bye
They always remind you is a patch up job of a broken catcher. This removes that feeling.
If only I had matching paint. I'm still happy at the result.
Bit of paint MF and it would look a million dollars
Hi MF,
Nice find! I like this Briggs Classic engine, easy to work. I have also pickup a Briggs 450 on kerb side and was badly neglected with no oil in it, no fuel cap, worst out blades, rusted muffler. I gave it another life for personal use. Don't have working mower for myself. Check the photos.
CM
1 member likes this: tortoise2
Hi Carbymaster,
that came out looking 100K at least.
Good to hear you keeping it for yourself.
Wow, THAT's to go straight to the Pool Room :-) Beautiful job !
Looks like he just unboxed it eh?
18,173 Registered Users
Posts106,820
Members18,174
