2 members (archernar, 1 invisible), 1,192 guests, and 970 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
YardKing 4 stroke spare parts
#117715 14/03/23 08:16 AM
Found it on Kerb yesterday. Missing starter. Drill method got it going after stalling on first two attempts. Pressing primer helped. Blade bar is good. Front axle bent.
Used old bearings as spacers to keep cowl secured down.
Hi MF,
I'm pretty sure that a Honda pull starter will fit and you can pick them up for under $20 Just not sure if that cup is a problem
Hi NormK,
I saw one on EBay and the mounting nut spacing was different.
how about a 3bolt sanli starter?
I have been thinking there are probably other brand's starters that will fit this Chonda.
I wish I hadn't chucked a bunch out recently. You just never know if you'll n need them. Hoarding has it's benefits.
Hi MF,
I'm fairly sure this one fits, I can check later today, I put one on a Chonda a week or so ago but there is a slight issue with the starter cup
https://www.ebay.com.au/itm/193816573727
G'day Mf ,Norm, Tyler,
I never buy starters as this Aldi mower serviced I would only get $60. for it with a plastic catcher, so I usually just cut a ring of sheet metal (old computer side wall) and use the sheet metal as an adapter (pop rivet the starter to the sheet metal ring then bolt the sheet metal ring to the mower cowl but sometimes you can just redrill an old starter to fit the cowl or redrill the cowl.
And as it is only worth $60 don't waste any time fitting another type of starter as you can easily end up spending a couple of hours doing it, best thing to do is put it back on the nature strip
Yes mowers aren't worth getting for free if you count the time it takes to fix them but if you see an old Rockwell mower the starter takes 5 minutes to drill and will fit the Aldi mower.
The pull starter on the Aldi mowers are one of their weak points, everyone I see has the pullstart missing
Here's my garden carrier 18 inches wide....... runs well...
You do get lucky sometimes with chondas.. i have had a few good ones.
I threw out a Wesco starter and cover only weeks ago.
That's what I suspected when I saw an ad for one with a missing starter.
I always keep chonda pull starts of all sizes.... some fuel hoses and carbs.....throttle cables......some blades and bars............
Hi speedy,
Always grab the stepped hose they put on some Chondas, they are a real pain if you come across one that is split and you have to replace it
Norm, what method do you use to make up replacements? I force victa line into 1/4in briggs line, put a thick fence wire inside, bend to the angle I want then heat up the victa line to develop a 90deg bend
Hi Tyler,
As you say, one hose forced inside the other but I haven't tried the wire inside, just make the hose longer and allow a longer sweep in the hose
Hi Mf ,Speedy ,Norm and Tyler,
Yes I always keep starters and starter cups etc when I throw the old worn out motors into scrap metal.
The last Chonda I replaced the stepped fuel hose, I just went to Clark Rubber and got some 8 mm (5/16) clear
hose and heated the hose before putting on the tank end and it worked well , it had to stretch a bit but better than
using second hand hose like I usually do.
I'd hate to know how many Aldi mowers I've had but most run like new ones, just about 4 that were worn out and the one
Mf has always has a busted starter as previously mentioned.
Max
Here are a couple of pics , you just bend the bracket that holds the fuel hose so the hose doesn't rub on the governor arm.
That certainly fixed it Max and I doubt the mower would be around long enough for the clear tubing to go hard
I have used clear, it stretches pretty well i hot water..
Just a built in rip-off item.
17,930 Registered Users
Topics13,086
Posts107,376
Members17,930
PHP: 8.3.30 Page Time: 0.092s Queries: 63 (0.081s) Memory: 0.7330 MB (Peak: 0.8615 MB) Data Comp: Zlib Server Time: 2026-04-25 02:15:20 UTC
