1 members (Hendo), 1,134 guests, and 1,747 robots.
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by mich - 08/11/21 11:08 AM
by NormK - 26/09/26 09:24 AM
by anna23 - 25/09/26 10:38 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#117045 16/12/22 08:52 PM
Mower storage ,I've quickly made a mower rack for a shed to store 24 mowers ,all the metal I got for free as it was a kids play equipment (monkey bars) so all up cost to build is under $10. for welding rods.
I like to store old mowers with the wheels off the ground so the tyres don't get flat spots and the old plastic wheels won't crack.The mowers
at the bottom I will store the mowers with the stronger wheels or I could use some bricks or wood under the bases of the lowest mowers.
There's a little more welding to do but just shows how easily you can recycle old metal for mower storage that won't take up a lot of room
down one side of a shed.
maxwestern #117046 16/12/22 09:22 PM
Hi maxwestern,
I used old metal shelving found on hard rubbish to allow three mowers on top of each other. Triples the capacity of one mower footprint. I've made up three of these so far.
That is on another level -excuse pun haha -can literally hold tonnes -well two anyway - of mowers with very little precious space taken up for the number of mowers you can fit. It looks safe too.
maxwestern #117050 17/12/22 12:43 PM
Hi Mf,
That's all you need a few of those metal shelves if you don't have too many mowers.
I think I have scrapped most of my rear discharge Victa mowers from the seventies up ,good mowers but people
are always giving them away just have to say no now :lol:.
On Gumtree there are a few Victa mowers for free in Wollongong, NSW.
maxwestern #117053 17/12/22 09:52 PM
Here I made most of my storage shelves out of those angle iron bed rails and reclaimed 3/4" plywood. I cut and welded mine but they probably can be bolted to together but require cross bracing as they would rack without it.
Welding will be at fix distance between shelves so some intermediate shelve might be add that just bolted in place so their distance can change by drilling new holes.
My shelving is on a 2' x 4' format with the height around 6'.
The only problem now is getting more rails as the scrapers are snatching up anything metal to sell.
maxwestern #117056 18/12/22 07:48 PM
Yes the scrap angle iron is very handy AVB ,I have the same problem I never have enough of the angle iron ,it
gets used up quickly on projects.
maxwestern #117077 20/12/22 05:35 PM
All finished.
Luckily I made the rack to be topless for maneuverability as it's quite heavy when complete ,I was thinking of bolting it all
together so it would be easily moved but it's ok to move when the top is removed.
Added a few cross bracing to strengthen the shelves and fitted some lower legs to stop the rack from tipping over.
I don't think the rack is too heavy as it's got to hold half a ton on the 3 shelves and it's 11 foot long., the top shelf
is probably stronger than it needed to be but I already had that part to start with just had to shorten the width of the
monkey bars and the top shelf was done.
Max
maxwestern #117080 20/12/22 06:28 PM
Hi maxwestern,
so the top shelf is readily detachable for moving?
Show us when you load it with mowers.
maxwestern #117081 20/12/22 06:44 PM
Hi Mf
Yes the top shelf just slides into the 4 poles.
It may take a little while until I fill the rack as I have to fix the shed now ,the front door hinges need to be unseized
and a few small leaks in the roof will be patched.
I will get some images when the racks are full.
maxwestern #117083 20/12/22 07:41 PM
I set up a rack a few days ago in a shed up the back and then I carried 30 Victa motors all with cowlings on them and put them in the rack. I can't get a pic because my camera has failed to work anymore and I can't use the one on my phone
Mowerfreak #117084 20/12/22 08:55 PM
[quote=Mowerfreak]Hi maxwestern,
Show us when you load it with mowers.[/quote]
Are you planning on storing complete mowers on your racks Max? I find manhandling mowers to be somewhat of a struggle even just lifting them on and off a trailer without using a ramp, mainly because they aren't grab-friendly items. Doubt I could get mowers up and down off your top two shelves on my own, at least not safely.
I know I'm blessed being able to store all of my fleet at ground level thanks to the surfeit of sheds that were on my rural property when I moved in.
maxwestern #117086 20/12/22 10:01 PM
Yep definitely need an assistant for racks above waist height, in my case anyway.
A pair of thick gardening gloves helps a lot in gripping the sharp edges of steel mower decks.
maxwestern #117087 20/12/22 10:13 PM
I'd like to make an engine rack Norm but have too many motors.
Yes MowingManiac I will fill the shelves with complete mowers ,the top shelf is only 150 cm high .
A mower is about a bag and a half of cement (30kg) .I been lifting mowers over my head to carry into a shed for years so
not an issue . The worst mowers I had to lift were 2 self propelled Honda mowers that I lifted onto the roof rack on the car ,also
probably sounds strange but I've lifted about 4 ride on mowers onto the boot on my car ,only 2 ride on mowers had the engines in them ,one
was an old Deutscher ride on ,then there was the 3 complete quad bikes I lifted into the boot .I just tied them down to the boot lid ,gas tank bracket and the tow bar.
To optimize the health of your body, you should be able to squat and deadlift ~1.5x your bodyweight, bench press ~1.25x your bodyweight, and overhead press ~0.75x your bodyweight.
I mostly don't wear gloves Mf then when I get home with the mower I see all the red backs under the mowers.Gloves are a good idea.
maxwestern #117088 21/12/22 01:38 AM
When I built up my wooden shelves, I deliberately made the first shelf just the right height that the front wheels reach the shelf while the rears are on the ground.
The only mowers I can lift above waist height is the little 16inch ones. Can lift a regular mower into the boot of a car easily enough. Problem in my case is due to a severe hereditary bone spur condition, I can't even squat lift anymore - a pointy spur (bone tumour) goes through the muscle about 3 inches above the left knee. I literally ran 5 steps 2 months ago, pierced it and fell down - couldn't walk for days. Pair that with the one under my left armpit (also pointy - can't lift my arm over my head if holding any weight) and it makes moving things around a real issue.
Whenever I squat or kneel down or get up, I am forever careful because it will just grab - fell over getting up from cleaning out a sprinkler head on sunday.
I am starting to know how Norm felt before the hip replacement a few years back.
I see guys lifting 17in sb45 mowers in and I just cringe
maxwestern #117092 21/12/22 08:38 AM
Max,
I would have well in excess of a hundred Victa motors here, which does include a pile of straight fueled ones I will never get to repair but who knows what the future holds. Once upon a time I could buy 2 FJ Holdens for $50 in the Trading Post with the heading "Build one out of the 2"
Not suggesting the 2 stroke Victa will ever be that sought after but the world is a strange place
maxwestern #117099 22/12/22 01:02 AM
They will become a quaint artefact once they become scarce enough. They'll be like a Lister is now.
Mowerfreak #117102 22/12/22 05:04 PM
Yes that would be a problem if you can't lift the mowers Tyler ,if I couldn't lift the mowers I'd get a manual forklift ,I've seen
second hand ones for $150. In a larger shed you could make an over head crane or possibly use a scissor lift table jack.
I haven't counted all the motors Norm but would not surprise me if they were over 200. Yes there were lots of bargains
years ago if you held onto old cars ,I had a Holden subframe in the shed that I paid $50. for and sold for $2500.
The straight fueled motors you can bolt them to a face plate on the lathe and rebore them if demand for them
goes up.
[quote=Mowerfreak]They will become a quaint artefact once they become scarce enough. They'll be like a Lister is now.[/quote]
Who knows Mf ,if everyone is using electric garden equipment in the future the vintage equipment may just end up as scrap metal.
Fixed the door hinges by drilling a hole and putting a 6 mm hose in the hinge then filled the hose with WD40.
I've put 23 Mowers on this rack so far ,I think I need to make another rack on the other side of the shed , one good thing
about using the round steel for the rack was it cost nothing to cut (no grinding discs required) just used a pipe cutter.
If I make another I will probably use something completely different for the other rack only because I think I have some
lengths of RHS to use up.
maxwestern #117103 22/12/22 06:55 PM
Phenomenal work getting so many organised like that. No wonder you got rid of so many. That didn't take long to fill up!
Neat bit of ingenuity on the gate.
maxwestern #117104 22/12/22 08:15 PM
And I spy a 24 sitting there Max, and this is my rack with 30 motors stacked away, some tested some not
maxwestern #117105 22/12/22 10:00 PM
Yes didn't take long to fill up Mf , most of these mowers were stored for years in the backyard under corrugated iron so it's
good to clear them out , now I can get to them ,I think there are about 4 mowers left in the back yard.
I needed to get the mowers into a shed as the Foxes were leaving dead animals on my mowers and crapping on them.
I still have a lot of mowers in other sheds so I may have to make some more racks.
Yep wasn't much wrong with that 24 Norm ,I used to go to a country area and I would pick up a 24 Mower for free ,
all it needed was a carby clean,there is still another 24 here to put in the shed.
People just throw them in the trash if you look in the non metro areas.
The reuse of old pallets is a good idea Norm ,I will have to sort the motors out eventually ,mine are just in a huge pile.
maxwestern #117106 23/12/22 12:01 AM
I spy a commercial grade SupaSwift top rack closest to camera and what looks like an old Masport below with the brown wheel covers.
The 24 didn't evade my notice. How could it?!
maxwestern #117107 23/12/22 08:20 AM
Max,
I chase all over Vic looking for Victa 24's Deutschers and Ariens, I got a 24 from Port Arlington a Deutscher R36 from Wangaratta, often the round trip costs me nearly a day
maxwestern #117109 23/12/22 09:29 AM
Max, obviously a LOT of mowers have come your way over the years. Just curious what criteria you have for particular mowers to go to the "Pool Room"?
At my place anything that can be coaxed to start and make headway through overgrown grass and weeds without belching too much smoke gets a spot under cover.
maxwestern #117111 23/12/22 06:39 PM
The mowers in the rack , not in order are ,
SupaSwift industrial with echo 2 stroke ,SupaSwift under the Industrial mower it's deck is an end cap off a hot water tank
A HG palmer 4 stroke ,a couple of 4 stroke Ambassador mowers , Victa Sheerline .a few sixties Corvette and Cortina mowers,
Granberg Parksman 4 stroke stainless base mower,a couple of sixties 4 stroke Turner mowers,Victa 24,a couple Victa 18 mowers,
a Wolf Garden with Kawasaki 2 stroke ,Masport with 2 stroke motor.
Norm, I bought a ride on mower from a guy that went to scrap yards buying complete ride on mowers for $50. each, then he would
sell them as non runners for min $150. ,he also had tons of push mowers that he fixed and sold , he paid $5. each for them.
A long time ago I would buy V8 motors from importers for $240. and just clean the outside and sell for $500. and they sold
quick. I kept one of those engines that I sold recently for $2500. and it needed a full rebuild.
If I spend 4 hours driving I would normally come back with at least 20 mowers.When I was in Melton I saw tons of good
mowers in hard rubbish but I wasn't looking to collect anything.
MowingManiac , sometimes I will give away a good running repaired mower or sell one for $10. or $20. just because I
don't want to see a rare perfectly good working mower thrown out but usually any thing that's not rare and I can't sell
for $50. even if I'd given the mower a service I would rather get rid of the mower straight away by scrapping the alloy base
and scrap steel .The mowers I can't get $50. for are good mowers with no damage but a lot of people I've sold mowers to
aren't interested in mowers that are more than 5 years old. At one stage I could buy a new ex demo GMC mower with a Briggs
from a shop for $100.
I don't really cut grass using a catcher unless testing a mower then I would tip the cut grass back on the ground so
I don't really need any rear discharge mowers ,when I started collecting mowers I would just collect side discharge mowers
but over the years I've kept a few of the harder to find rear discharge mowers mostly from the sixties and have kept some seventies
rear discharge mowers, so I don't have the spare time to fix and sell mowers for $50. or less better to scrap them , I also started off
collecting 2 stroke mowers only but have kept some older 4 strokes.
Pool room mowers I'd say are first model mowers like model 1 Rotomo ,first Turner ,Victa auto,first SupaSwift or can just be an
old mower that you don't see many of . I've basically just scrapped all the mowers that I could easily buy as a non runners for $10.
maxwestern #117112 24/12/22 09:31 AM
Thanks Max, very interesting. I've not seen that type of quality machines when I was picking mowers off the street even though I plundered the leafy well-to-do Melbourne suburbs of Malvern, Armadale, Toorak, Kew, etc. on Hard Waste days.
My latest rescue was a Honda Buffalo HRU 194, probably the only one of my fleet of 20 runners which could be a Pool Room contender. I thought I had more than enough but the allure of a genuine Honda OHV for free was too much to resist. All it needed was TLC and it is doing an exceptionally good job slashing rough stuff, albeit a bit heavy to push uphill. The governor system works perfectly, something I usually disconnect on other machines.
maxwestern #117113 24/12/22 12:06 PM
I've never looked for mowers in those types of areas MM ,the Median House price in Toorak is $5,190,000 ,I always find those areas the people will mostly pay someone to take the rubbish away or pay someone to cut the grass.
When I picked up hard rubbish mowers I would find a lot of late model mowers some 3 years old that just needed a spark plug
or an air filter clean , all the mowers on the rack I paid for them, except the Victa 24. I would sell the later model mowers and
buy / keep the vintage harder to find mowers.
I guess I've never searched areas like Norm gets mowers from as I've never heard of so many straight fueled 2 strokes ,I've picked
up a few hundred over the years and only had about 5 straight fueled 2 strokes.
A lot of the time I didn't bother looking for mowers for free as there were a lot of tip shops selling mowers for $10 each.Even
when mower shops closed down they would sell old mowers dirt cheap.
maxwestern #117193 31/12/22 05:21 PM
G'day all
I've got the next load of scrap metal to make another mower rack. Last time I bought arc welding rods they were $10 to $15 (pre covid) a box
at a shop but as everything has gone up lately I think online they are about $25 now but still around a third of a shop price.
I think this rack will have a few bolts to hold it all together otherwise it's going to get to heavy to move ,if I get rid of
a few more mowers this rack would make a good engine rack as the crack shaft on the motors would fit in the square mesh.
maxwestern #117197 31/12/22 07:45 PM
I'm going to have to get rods soon Max and during covid my source in Bayswater closed down. I have never had any joy looking for rods on ebay. but my son found 3 brand new never used GIG welding helmets on hard rubbish at the bottom of our street a couple of weeks ago
maxwestern #117198 01/01/23 12:24 PM
Yes all the arc rods I've used lately Norm were the Swec in a 2 kg box for $12.98.
If you buy rods in a lot of 1000 boxes they are $4 to $6 a box.
I bought some stainless arc rods on eBay probably 1 KG and they worked well and were cheap but
no idea of the brand as they were wrapped in a plastic bag.
I see cheap rods on eBay but I would normally look for a brand that I know is ok.
All the cheap places I knew of for rods have closed ,i think I will just go to Bunnings and get the 2kg of Bossweld rods
for $22.98. Maybe I could check a few places that I've been to before but usually find they are no longer there when
I haven't shopped there for a few years.
The new CIG welding helmets was a good find.
Just found Sydney Tools has Gigweld 2.5 mm 2.5 kg rods for $24. If any one knows a good brand that's cheap let me know.
maxwestern #117199 01/01/23 01:24 PM
I will go back to Arctec Sales in Hammond rd and get some. I used to get them there before I started going to Bayswater
maxwestern #117200 01/01/23 01:57 PM
I think you'd like West Gosford near where I live maxwestern and NormK. There's a road full of industrial supply sellers like Total Tools, Sydney Tools and at least a couple of independent retailers of welding equipment and supplies who also sell tools.
There are two mower shops on opposite corners of a T intersection and a bearing supplies shop opposite them. They are abit dear wanting $7.00 a bearing for ones that fit a Victa wheel. They probably want closer to a tenner now.
One mower shop is primarily a Stihl dealer and the other Husqvarna. The guy I've dealt with at Stihl is not very friendly and the Husky dealers were better.
Moderated by  bigted, Bruce, CyberJack
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
Bushmechanic, Eltenj, Murray K L, Bibi38, anna23
18,129 Registered Users
Topics12,754
Posts106,800
Members18,130
