1 members (Buckets), 3,682 guests, and 570 robots.
#108123 31/08/20 12:08 PM
I have two issues.
First, out gravel driveway is overrun with weeds and grass. I use to spray Roundup on the small patches, which took 3weeks(ish) before they were brown/dead, and they would stay dead (though still visible) for a period of time, then would start growing back after some wet weather. I had planned on tackling it more frequently as it grew back, but this time, it's really gotten away from me, and now since having rain not too long ago, looks close to being a lawn.
[img]https://i.imgur.com/073iG7b.jpg[/img]
Aside from getting a mini-dozer and and inch out, then putting fresh gravel in, can anyone recommend on what to do in this situation? Spray with grass/weed killer, then maybe burn their corpse ?
Secondly, we have a small shed in the backyard. I rarely go behind there, but did the other day, and noticed a lot of some vine-like weed along the ground, and climbing the back fence. Stepping on the weed sounds sort of rubbery, like walking on lino with shoes. Anyone know what it is and how to kill it? Weed spray again? Or perhaps better to get the whipper-snipper in there (or mow), then rake it out, then poison the area ?
[img]https://i.imgur.com/Nf1J5t5.jpg[/img]
[img]https://i.imgur.com/6hhTKw1.jpg[/img]
I should note, we have some cats, and the neighbor has a dog, so if there's a poison you might recommend, preferably pet friendly. :)
Thanks in advance,
Hi Widget,
Something I have never tried so I don't know how effective they are is one of those propane torches, just make sure along the back fence that you don't start a big fire.
IMHO and from the rural property we live on:
For the gravel driveway - you can use whatever you like to kill the existing stuff in there. Glypho will work well now as its going into Spring - but you could even use salt+vinegar if you wanted on a hot day. I'd not worry about removing the dead remains, it'll decay away soon enough. Consider using a residual herbicide every 6-12mths to ensure it doesn't come back - Simazine is regarded as one of the better choices, Bunnings sell a product but you can buy better value/strength ones on Ebay or at a good Ag store.
https://www.bunnings.com.au/brunnings-1l-path-weeder_p3013486
For the weed near your shed I'd just spray with Glypho.
None of it should be an issue - just apply patience but glypho only works when the plants are growing and they will be soon.
I once had a kerosene weed killer. It was a metre long, and you pumped it up and heated the coils to vaporize the kero. It used to roar.............
Pity you don't see any around nowadays...
Hi speedy,
I guess the old kero setup was a bit of an OH&S risk and these days kero is expensive compared to petrol whereas it used to be the other way around. I remember all those kero powered tractors before diesels became the only way to go.
I would suggest glypho, but with pets...
Salt, vinegar with a good squirt of dishwashing liquid has worked for me. The dish liquid is a surfacecent - apparently helps uptake by weeds.
or old engine oil ,cooking oil ... run in neat lines down the drive.
You can get an LPG fired equivalent!
https://www.jamesshields.com.au/shop/category/weed-burners-and-hoses
Or even;
https://www.bunnings.com.au/tradeflame-870mm-propane-torch-weed-burner_p5910467
Long term weed control for me is in the shape of a pre-emergent. It works to stop seeds germinating, and in the 3 years I have used a Prodiamine based spray I have not had an issue.
You can buy from an Aust supplier and get say 1L of 48% for over $200 a bottle, or look online for options. I bought a 2.5kg container at 65% strength for close to $150 - far more economical and I have a healthy stock that I have shared to family etc.
My application rate is 12g in 5L sprayer per 100m and then water in with a half inch. I do that 3 times a year and I just don't get weeds any more. Works for me on Poa, crab grass, bindii, broadleaf.
Right now is the time to spray before it warms up and those dormant seeds reach for life above ground.
TC.
[quote=NormK]
Something I have never tried so I don't know how effective they are is one of those propane torches,[/quote]
[quote=speedy]I once had a kerosene weed killer. It was a metre long, and you pumped it up and heated the coils to vaporize the kero. It used to roar.............[/quote]
[quote=Gadge]You can get an LPG fired equivalent!
Or even;
https://www.bunnings.com.au/tradeflame-870mm-propane-torch-weed-burner_p5910467[/quote]
Thanks guys. I had a look at those long-nozzled propane burners, but the price was a little high, as I don't have a propane tank either :/. I have a tiny burner that clips to the top of a butane camping can that I mainly use for rusted nuts/bolts, I also used it on some weed leaves (white flowers, chemicals couldn't kill them, can't remember the name). Being a fair amount of weeds, it would be a big job for a tiny can lol.
I came across this cheaper propane torch, wondering if that would do the job too?
https://www.ebay.com.au/itm/Garden-Propane-Weed-Burner-Torch-Killer-Grass-Shrub-Gas-Fire-Lighter-1200/353176227735?hash=item523af18f97:g:QVAAAOSwr5FfCTRU&frcectupt=true
What's the cost of those little white propane tanks + propane these days ?
[quote=N1KK0]
None of it should be an issue - just apply patience but glypho only works when the plants are growing and they will be soon.[/quote]
[quote=Tyler]I would suggest glypho, but with pets...
Salt, vinegar with a good squirt of dishwashing liquid has worked for me. The dish liquid is a surfacecent - apparently helps uptake by weeds.[/quote]
Thanks guys. The Roundup I used was Glyph based. Is there much difference between that and "Simazine" ? Thanks for the links, I'll have a poke around and see if I can find some stronger mixes to make my own ratio.
Regarding the weeds near the shed, I think they've been growing for some time, and they're in the shade too. Would it be better to chop it all back, then spray the exposed stems, or would spraying on the leaves have the same affect ?
I've heard about the vinegar+salt+dishwash liquid before, but never tried it. Is the effect much different than weed killers ? What's the general ratio for each ingredient you guys use ?
[quote=speedy]or old engine oil ,cooking oil ... run in neat lines down the drive.[/quote]
Hey Speedy, what does the oil do? I have heard of people mixing Diesel + weedkiller, though having Diesel (or other oil) on the gravel would create a messy-rainbow effect when wet, wouldn't it? Would it be better to rake back all the stones to reveal the dirt, so it absorbs better, then push back the gravel ?
[quote=TheCount]Long term weed control for me is in the shape of a pre-emergent. It works to stop seeds germinating, and in the 3 years I have used a Prodiamine based spray I have not had an issue.
/quote]
Thanks for the suggestion :). The price though is a bit steep for my pockets lol. Is there a cheap option, and is that stuff in concentrate form or ready-to-use ?
[quote=NormK]Hi speedy,
I guess the old kero setup was a bit of an OH&S risk and these days kero is expensive compared to petrol whereas it used to be the other way around. I remember all those kero powered tractors before diesels became the only way to go.[/quote]
I remember reading that some time ago, where truckers would use Kero instead of Diesel because it was cheaper, and to avoid Diesel tax (which added to price), as Kero wasn't taxed. I remember it read that they added a colour to one of the fuels, and what would happen is, regulators/inspectors would do random inspections of the fuel to see if they were using Diesel or Kero. Can't remember what country this was happening in though...maybe Australia, Euro, or UK somewhere.
Thanks again for all the feedback, much appreciated :)
/quote]
Thanks again for all the feedback, much appreciated :)[/quote]
Breaking news!!
Bunnings are about to start selling an Amgrow branded pre-emergent. Check out Lawn Tips on Youtube for more info..
My Prodiamine is granular, hence the measurement in grams. At my rates, I’ll have 20 years worth of weed free lawns.
TC.
I never quite got around to weeding :/, but now it's Spring, it appears things are growing again. I have attached more pics of the weeds I have.
The weeds in the pics are on the lawn. What do you guys recommend that's safe for grass ? I was going to get one of those RTU containers with the hose attachment and hose the lawns with weed n feed, but figure it might be weak, or there might be a better chemical that's safer on grass.
Regarding Amgrow, Bunnings are selling it now though I don't know which is best, but they says it's for lawns so I guess it must be safe for grass lol ?
As for the weeds on the driveway, it has more grass there now. Wondering if the Brunnings Path Weeder kills grass too or just weeds ?https://www.bunnings.com.au/brunnings-1l-path-weeder_p3013486 , otherwise I may have to go back down the Glypho route. Anyone know if Simazine it pet friendly or would i need to lock them up for x hrs ?
[img]https://i.imgur.com/2CdOj12.jpg[/img]
[img]https://i.imgur.com/LsKqsTq.jpg[/img]
[img]https://i.imgur.com/3qQNONO.jpg[/img]
[img]https://i.imgur.com/v9sCxwh.jpg[/img]
[img]https://i.imgur.com/B39vIRC.jpg[/img]
[img]https://i.imgur.com/cTvP8BT.jpg[/img]
[img]https://i.imgur.com/EEGlN0L.jpg[/img]
I think 80% of those would be taken out with 1 or 2 applications of plain old buffalo weeder (Bromoxynil and MCPA) - eg yates buffalo pro or in bigger 1l bottles superway buffalo soldier.
The first photo I am not sure - may need dicamba on it.
The last photo with the purple flower is a problem - hard to judge by scale but it looks like some sort of onion weed. There are some chemicals that will do it but they are around $400 for 200ml and are schedule 7 - need a spray cert to legally buy it.
I have had some success using metsulforon methyl - but it is somewhat nasty stuff and should not be used near plants or trees you don't want to accidentally kill.
Edit - lock your pets up for anything - just because its supposedly safe doesn't mean it is. many people have made their dogs seriously ill due to simple bifenthrin ant spray
Hi Tyler,
I have had good success with onion weed. I cut the onion weed above the ground and then with a thin paint brush paint the stalks with glypho straight from the bottle. I use that method on any sort of weed I have had trouble with. I have used it on black berries but I never heard how well it worked because the people moved out 12 months later.
Old fuel works on weeds growing in cement. Nuclear waste would probably be a bit overkill.
Thanks Norm, I will give the glypho a go. the problem with onion weed is the waxy coating doesn't let it through - I hadn't thought of cutting the end to expose it
Spring here, bindi and a thousand other weeds in my lawn. So I used weed n feed, should work..
Thanks for the feedback guys :)
I picked up some ZERO Glyphosate and Bin-Die today...
https://www.bunnings.com.au/yates-1l-490g-l-zero-weed-killer-super-concentrate_p3012676
https://www.bunnings.com.au/amgrow-250ml-bin-die-selective-lawn-weeder_p2990227
damn, Glyphosate is pricy. Pretty sure I payed <$30 last time for the Roundup brand :/. Is there a cheaper or a recommended place to buy lawncare chemicals ?
We had a bit of rain here yesterday, but next few days are expected to be clear. I let it dry out a bit today, will hit the driveway in the morning and paint as many weeds as I can with Glypho too. I'll leave the Bin-die for larger patches as I only got a 250ml bottle.
Speedy, what weed'n'feed did you use ? I'm looking to get some fertiliser to use as well.
Go to an ag supply store. Bigger bottles but a lot cheaper overall. I have been buying quite a few of the 'apparent' and 'surefire' br
But do your research, some things are no cheaper. eg you paid $17 for 250ml of bin die ($70/L) Surefire buffalo is $75/L.
Regarding glypho, its a good example of grams per litre being $$$. You got 450g/l high strength. You got 450g of 'pure' glypho for $50.
I can get Apparent 'concussion' (they have funny model names) 540 for $50. Thats an extra 90g of pure glypho for the same price. I can get Surefire glypho 540 for $35 at my local ag shop, but they tend to be fairly cheap.
While you are at the ag shop - pick up a 25kg bag of ag grade epsom salts - mix it in about 2kg with every 8-10kg of fertiliser. Works good. Bunnings have it in 1kg packs for $8. That means $200 for a 25kg bag.
25kg bag at an ag shop - $35 max. Theres your mark up.
Regarding weed and feed, there are 2 types and unfortunately neither work great.
Granular weed and feed is simply iron sulphate and urea (or nitrogen of some description - might be sulfate of ammonia). You put it on, don't water it in. Everything turns black (iron overload) weeds die off and lawn comes back. 12% iron, rest ammonia - I can make it up for 1/4 the price bunnings charge. All it is is a few % iron, few % ammonium sulfate (as an aside, this mix is sure to lower soil PH as both are acidic).
Literally 1950s tech.
The liquid weed and feed in the spray 2l bottles is literally what you bought concentrated today but with a couple of extras (bit of nitrogen and iron). Basically you are paying for it to be watered down. The main problem is its too watered down by the sprayer - the water washes the chemical off the leaves. If you have a lawn covered it weeds, it will help.
It is not a complete lawn feed all it is is nitrogen. You need phos and potassium (P and K).
Without offending anyone, weed and feed will turn a poor lawn half decent. But it won't do much for a lawn that is already decent.
You are better off buying a 20kg bag of a decent granular lawn fertiliser, then backing it up with a foliar application of liquid fertiliser like powerfeed.
As Tyler has suggested you can get significantly lower prices on $ per volume basis from Ag suppliers than from retail outlets.
One caveat on this is that you’re likely going to need to buy a larger volume than might be used in a single application in a domestic-type setting. You’ll need appropriate equipment to handle the concentrate(s) and then need to store the rest of whatever you may have purchased. Although these chemicals are relatively safe to handle you do need to observe precautions as unintended spillages can cause a range of undesirable outcomes.
With respect to storage I’d strongly suggest reading both the MSDS and the product literature to properly understand what is required. Many Ag chemicals need to be stored in darkness in temperature stable conditions. If you don’t do this they degrade much faster and have significantly reduced efficacy or, in some cases, unintended outcomes. It’s not much good buying something at 1/4 the price if it’s gone off by the time you use it.
Another source of wisdom on maintaining a low cost patch of green can be greenkeepers working at golf courses. The things they use have to be relatively inexpensive, very effective and not cause unpleasant reactions to people using their facilities or the native bush. A few years ago I was put in touch with a firm that supplies to golf courses through a golfing friend and I’ve been pleasantly surprised with the products.
Regardless as to what you use I would suggest finding out what the active ingredients are and comparing the prices on a dollar per gram basis. It can be worth asking people in your local area what they use and how it works for them. Sometimes things get swanky labels and marketing guff but there’ll be a generic product available at one tenth the price. Other things are absolutely brilliant at a particular job, cost 20 times the price of what you can buy at a retail outlet but are absolutely worth it.
For example, I use a particular set of commercial weedicides to kill blackberries. They’re more expensive, but I’ve found the generic products to be only 50% effective whereas these are 95% effective. I’m happy to pay a little more if I can get the blackberry under control a couple of seasons earlier and other plants established rather than wait what can be a further two years to establish cover.
Thanks guys :), I'll have a look around for the nearest Ag store and see what they have.
Since my last post, Using Glypho, I gave the driveway a spray, but also, using low pressure in my pump-spray bottle, I spot sprayed the weeds on the front and back lawns. One thing I was wondering though, how much is needed in order to be effective? I pumped the bottle to low pressure so only minimal came out, then I gave a quick spray on the leaves of the weed. this is enough isn't it ?
I didn't use the Bin-Die yet, figured as I'm spraying with Glypho, I'd try knock out what I could see with that first, then come back later for any missed ones with the Bin-Die.
very little is needed to be effective, hence the invention of the weed wand.
Ironbark is correct regarding storage - luckily its something I don't have to worry about too much. any of my expensive stuff or stuff in larger bottles that need to last a while I keep under the laundry sink (eg fipronil, fusilade, imidacloprid, stadium turf, etc)
The product information sheet will describe both the recommended dilution and application rates in quite a high level of detail. They are required to do this. It will go into such things as the correct droplet size.
I buy some of these things in 20l drums and store them in a separate locked building. I also keep a book on when, where and what I apply in what volumes not because I’m required to but because I apply different things in different seasons at differing application rates and I want to monitor the effectiveness.
Yep, I keep a notepad in the shed as well and note all my applications as I have a memory like a sieve and things like accelpryn and pre-emergent have to be applied at the right times
My 2 cents worth for this problem,
If you have a lawn, which is predominantly common couch [[i]Cynodon dactylon[/i]] then the best way I have found to keep it pure, is to spray the entire lawn with Roundup, which you must use at half rates [e.g. the recommended rate is 40ml/litre] from memory, so you would use 20ml in a two litre container, along with a teaspoon of dish-washing liquid, which acts as a surfactant. Of course the rate and quantity of water you use will depend upon the size of the area you are spraying.
This you must do in early Spring, and one spray will not be enough, you will need two, or possibly more, depending on the infestation, and don't spray if you are expecting rain within a 24 hr period.
In my case, when the couch is growing vigorously, the process kills every flat weed, Winter grass, Bin-Die, Creeping Oxalis etc., and to a degree, makes the couch look a 'tad' crook, but after a couple of weeks, it virtually "jumps out of the ground" you will have a pure sward.
I too, keep notes on when and where and what was sprayed, for future reference...
18,183 Registered Users
Topics12,763
Posts106,822
Members18,184
