2 members (looktall, aitchey), 5,375 guests, and 665 robots.
Page 3 of 3 1 2 3
NormK #115683 17/06/22 03:45 PM
I can report that the Victa Vac is a fantastic piece of equipment in the right setting.
We have a decent number of deciduous trees and vines around the house and many of them don’t even start dropping leaves until late autumn. The Victa vac is great at sucking up larger volumes of leaves that would otherwise be pretty unmanageable. I previously picked them up with a normal mower, emptying a catcher repeatedly into a trailer and by raking up big piles and transferring them. Now, provided the leaves are not wet, I can do the same job in half the time.
I have the big vac out twice a week at the moment, weather permitting. A couple of hours of leaf vacuum work and I’m ready for a change of pace.
NormK #115684 17/06/22 07:02 PM
Hi Ironbark,
I used the one I have here on a nature strip I had cut with a 24, which was excellent along the footpath and the road/gutter but when I tried on the nature strip the front height adjuster wheel kept digging into the ground. I was thinking it might work better with a mower type wheel on each end of the vacuum chute
NormK #115685 17/06/22 08:38 PM
I used a hand held blower vac to suck up several small but dense piles of leaves and sticks and it was slow going and clogged a fair few times where I had to pull out a clump of twigs blocking the chute.
It would have been simpler just to put it all in the bin by hand by the time I fitted the vacuum attachments and the weight of the machine and bag.
Wasn't helped by the motor wanting to cut out periodically thanks to a new found flat spot.
NormK #115686 17/06/22 10:45 PM
G’day Norm
Yes, that can be a bit of an issue. Most of my use is on grass and I pull the front wheel fully down against the stop when doing so. Because of the turning issues and clearance at the corners I was thinking that I might make a larger diameter single front wheel. If my grass was thicker thatch then I’d already be on to it but most of the time it’s not a big problem so long as I maintain awareness.
I’d dearly love another couple of bags for the thing but it seems they’re out of production.
NormK #115687 17/06/22 11:22 PM
Hi Ironbark,
I am thinking of scrapping the one here so if you want the bag we can sort that out
NormK #115688 18/06/22 01:08 AM
A Powertorque vacuum cleaner would be handy for vacuuming the house. The carpets will come up like new! Just remember to open all the doors and windows.
NormK #115689 18/06/22 09:38 AM
MF, the carpet might end up in the bag
NormK #115690 18/06/22 11:22 AM
Yeah probably not a good idea having a souped up vacuum cleaner in the house Mf and Norm. laugh
It's funny how the term souped up comes from giving horses narcotics to win races.
NormK #115691 18/06/22 04:16 PM
Gee I forgot how truly shocking The Young Ones was.
I wouldn't mind that engine on a mower but a helicopter turbine would be better. It would mulch the grass into a fine mush!
Those memes were classic.
NormK #115705 19/06/22 07:07 PM
Hi Ironbark,
Let me know if you go down that route. Assuming you’ll be using the parts common to a Super 24, there’re a few other vac bits I’d like off it as well.
NormK #115707 19/06/22 09:40 PM
Hi Ironbark,
no problems, I'm fairly sure I will end up chopping it, shame but as parts get a bit hard sometimes you have to sacrifice some things.
NormK #115709 19/06/22 10:12 PM
I'd love a Powertorque Victa Vac for my garden. It would certainly get the neighbours talking.
NormK #115710 19/06/22 11:38 PM
Mine sounds a bit like an early aeroplane. Definitely not something to use without good quality hearing protection as the muffler points straight at the steel fan housing magnifying the noise which then comes directly back at the operator.
NormK #115711 20/06/22 06:38 PM
Definitely not neighbour relations friendly if it reminds them of an airport!!
NormK #115712 20/06/22 06:59 PM
I was using the PT one a week or so ago and I can't recall it being too noisy. It doesn't have the right cowling on it because when the mower shop pulled it apart they didn't put the cowl back on so it has gone for good
NormK #115719 20/06/22 10:45 PM
My nearest neighbour isn’t within shouting distance so impacts on neighbours are not really an issue for me.
I have half a dozen Victa 2-strokes that see use, including one with the old “fishtail” style exhaust and the Victa Vac is significantly louder than any of them. I don’t mind the noise. I mostly have full-crank motors which have a feel to them that I particularly like.
I’ve been using heavy equipment since I was at primary school. A lot of it, particularly in the early days, was a bit rough around the edges. I’ve played music since I was a kid too and we’d wear ear muffs back then before most people. So now, if something might be loud, I wear earmuffs. Some things are too loud even with good earmuffs so in those situations I wear earbuds as well.
Page 3 of 3 1 2 3
18,154 Registered Users
Members18,156
