0 members (), 2,927 guests, and 999 robots.
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 12/05/26 05:58 PM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
by NormK - 07/05/26 08:42 AM
Image Upload Issue
Testing
by Bruce - 03/05/26 03:39 PM
Page 2 of 3 1 2 3
I probably should mark their locations on the house plans
Not marking locations is half the fun Norm
if you do make note on the plans, mark it WW2 surplus bomb haha
Hi all and Norm,
That is funny Norm ,burying bottles in the ground ,I hope you didn't bury any alloy bottles as that's a lot for scrap alloy these days.
If I threw out a complete bottle I would just dump it in a free scrap metal bin ,lots of places have free scrap metal drop off ,
tips ,car wreckers ,and some scrap metal yards have a big bin out the front .These days I have seen some signs on the
bins that say no pressurized bottles to be dumped in scrap bins .
All the last bottles I dumped ,I would unscrew the brass fitting with stilsons and cut one end off with the angle grinder
then sell the steel for scrap.
Just cut the top off and it's no longer CIG BOC etc..
Scrap yards just don't like closed bottles once you cut the end off they could not care less.
I know of a few places here that you could dump the bottle in a free metal bin but not sure where in your area but
if you cut the top off the bottle the scrap yard you go to will pay for the scrap but don't take the end cap that you
have cut off at the same time as the bottle or throw the end cap in the scrap bin at the tip.
It looks like you won't be getting any more welding rods from FJs Discount Tools Norm as they have closed down.
Hi Max,
How did you know I had been getting my welding rods from FJ's, I knew they were closing down but didn't have time to get there to restock my rods. Will have to find another supplier. No I have only buried the steel bottles. Doubt I would be too comfortable cutting the top off an acetylene bottle but I guess that is no different than cutting up car gas tanks and I have done a few of those over the years
I got my rods from FJ's and I remember you saying Norm that's where your rods came from.
Yes the safest way is to fill the empty bottle with water before cutting but I don't do that most of the time when
cutting up gas tanks etc ,I fill the empty bottle with compressed air a few times and empty and repeat until
the air coming out of the tank can not be ignited with a lighter .
The scrap yard here will take a complete gas tank so you don't have to cut them up.
I guess the bottles will eventually rust away in the ground just might take 100 years.
I did see an alloy bottle after it exploded and it took out a lawn mower lol.
Max, what am I looking at in that second picture? I see a briggs crankshaft and rover blade disc
Everything else looks ceramic?
Those images were from a 2009 bush fire Tyler ,not much left of the lawn mower.
before and after of a FX.
Thank you guys for your input. Since i only have the propane torch, will probably give this a try unless i find a place which can do it.
Hi Shannon, let us know how that works out.
It’s not impossible, I’ve done similar brazing jobs when I’ve had no options.
I might repeat myself but here are my suggestions
make sure all the mating surfaces are completely back to bare metal (no corrosion, plating, paint etc)
that they are clean of dust and any other deposits (a drop of oil will cause failure of the joint)
Ensure the surfaces mate uniformly to one another (I.e. that there are no burrs on edges or depressions in surfaces)
Ensure a good fit, the surfaces must be snug but with sufficient movement to generate the capillary action required for brazing to occur. With tubing this is loose enough to allow the pipes to slide by hand but tight enough not to wobble.
Most of the work is in the preparation. The temptation is to rush to the heating stage however, those that do rarely have success. A little more time and effort with cleaning and ensuring the correct fit will save a lot of frustration later.
Make sure you have the correct filler rod for your job and the right flux.
Construct a method of containing and concentrating the heat around the parts. Fire bricks are best but failing that use some form of fired masonry. I’ve used terracotta tiles, old red bricks, clay pavers and on one occasion, a large broken terracotta pot. Don’t use stones or anything made of concrete, it can explode and injure you badly.
Get the steel to a dull orange (beyond red heat but not bright orange) and then apply the rod to the steel and allow it to melt and flow into the joint.
Don’t try using the torch to melt the rod, that will just make a mess and even if some joining does occur it will fail under any load.
Best of luck!
Thank you Ironbark for a very detailed explanation of your suggestions and tips. One thing i'm not sure about though is what is the correct filler rod and flux that i should look for. The last time i went to check this out there's a few types and ended up not buying any.
There are I’d say three common options for brazing steel
Manganese bronze, a general purpose rod that needs about 900 degrees, good filling capability
Nickel bronze, a high strength and wear brazing material, needs more heat, great for teeth on gears or bushings.
45% Silver, good strength, needs about 650 degrees, requires close fitting components and cleanliness. Rods are more expensive
For your job I’d either pick manganese bronze or 45% silver. Manganese Bronze needs more heat and you’ll struggle with heat but 45% silver does need good surfaces that are close fitting. If you’re prepared to do the work to get a good close fit and clean up thoroughly I’d go with the silver.
The brazing fluxes are usually high or low heat or paste vs powder choices. Basically borax to prevent oxidation and aid flow.
If you go with the 45% silver a standard paste flux will work. If you are using the manganese bronze a “Tenacity” flux for higher temperatures will be needed. For pipe-style work I’d use paste flux.
With this job if you’re using an internal sleeve I’d probably trim the handle so that there is a slight gap where the sleeve fits. This way you can get the filler in both sides and once filler rod has wicked up well then fill the gap with more braze. After it’s cooled you can grind the filler back to get a smooth surface before etch priming and painting. Clean off all the flux and muck before paint or it’ll just blister and peel.
A couple more things:
If you elect to go with 45% silver it pays to check very carefully that you are getting exactly that. The lower alloys will not do the job. Commonly you’ll see way more 34%, 15% and 5% silver rods and someone may say, “oh you can use 34% - it’s only 2/3 the price”.
The 34% is not for high strength applications in steel; it does work for certain applications with specific steels but I almost guarantee that a mower handle won’t be made from that steel type. 15% and 5% are for brazing copper pipe not joining steel.
Also, you’re going to need to get the heat into your assembly uniformly. Then once you get a bit of a glow in the material just touch off your rod on it. The right temperature is when the rod melts on contact with the heated metal and flows smoothly.
It will be possible to get your parts too hot for the Silver brazing. They need to just be slightly above melting temperature for your rod. If it’s too hot the flux will be driven out and molten rod material will run through the joint. I heat the components to what I think is right and test touch, then heat some more, test touch again until I get a nice flow.
If you can do a bit of practice on some similar material before then you’ll get a feel for it. I wouldn’t recommend trying this for the first time on something you care about.
Thank you Ironbark for your hints and tips. Will keep your note handy when i'm doing this. Time to look for the brazing and flux materials.
Best of luck. It should just say “silver brazing flux” on the flux tub.
I had a look at mine today and realised, even though I don’t do a heap of this type of work, I have several different fluxes. So I can see that the choices might be daunting.
Found manganese bronze at 2.4mm and 45%silver rods at bunnings and yes you're right the silver is double the price. Will the width of 2.4mm be ok ?
To cut cost, i think i'll be going for manganese bronze but then it says it require a copper and bronze type of flux. This is the only avail flux in Bunnings https://www.bunnings.com.au/silver-brazing-flux-250g_p5910515. The label say 'Silver Brazing Flux' buti says on the description Ideal for brazing of steel, nickel, brass, copper and stainless steel. Do you think it is ok ?.
I have doubts you’ll be able to get enough heat into your handle and sleeve assembly to adequately flow the manganese bronze filler using MAP gas. You’ll need the entire portion of the assembly being brazed to be at 930°C which I’ve only ever done with Oxy-Acetylene.
The benefit of the silver is that it only requires around 650°C which is achievable with MAP, although you’ll still need to take care to ensure uniform heating.
That flux is for using when silver brazing all the listed things, I.e. it is a flux for silver rods. If you want to try brazing using bronze filler you need a flux specifically for brazing using bronze filler rods.
It should only require three rods to do the job. I think this is a fairly ambitious first brazing project; in order for it to work you’re going to need to have every factor lined up in your favour.
My advice is just find somebody who can sleve it and weld it up properly. The way you are going is you are going to spend quite a bit of money on rods and fluxes and still end up with a joint that will most likely fail because the weight you are trying to lump around is way too heavy for this weld to hold
You've got a valid point NormK. The cost of materials is not cheap plus i need to get safety gear on top of this. It might end up more expensive than buying a replacement upper frame.
Will see if i can find someone who do a small job like this. I was getting excited doing this as i may have to do a similar job on the engine starter cord assembly as the holes which hold it in place is worn out.
Hi Shannon,
Not knowing where you are in Aus makes it a bit difficult but I would be happy to repair it for free but that all depends on how hard and expensive it would be to post it
Page 2 of 3 1 2 3
17,955 Registered Users
Topics12,726
Posts106,648
Members17,955
(Release build 20251126)
PHP: 8.3.30 Page Time: 0.118s Queries: 57 (0.109s) Memory: 0.7351 MB (Peak: 0.8532 MB) Data Comp: Zlib Server Time: 2026-05-12 23:20:58 UTC
