0 members (), 6,510 guests, and 560 robots.
#115390 18/05/22 06:36 PM
Hi guys,
Just bought myself an Olympic 500 for a bargain ($80)
Started 2nd pull, and off she took. Luckliyi was holding on to the handlebars and was able to engage the clutch.
This is my first cylinder mower and just wanted to know is there anyway to dial back the speed these things move at. This mower just wants to take off.
I've only done a couple passes in the backyard with it, trialling dialling down the revs, but it still seems to be humming along real quick.
Im probably doing something wrong lol, but thought this was the place to get the best information.
Im going to be tidying her up, and repainting. Bloody stoked with my purchase thou (wife not so much lol)
Just lay new lawn out the front and can't wait to get this on it.
Have posted in correct forum. Apologies
Last edited by Nzboon; 18/05/22 07:41 PM. Reason: Wanted to delete post as I found right forum to post.
G’day Nzboon
Once the clutch is released and the mower is moving the usual method of speed control on these is through the throttle.
I have a very similar model and I found that there had been a few alterations over the years that needed to be put back to original specification in order for me to have it work correctly. You might have to do a bit of tinkering to get the rev range correct.
The first thing is to ensure that the choke is engaging and disengaging correctly with your start up procedure. If the choke doesn’t fully disengage then you’ll always have issues.
Next check the idle speed, this will be the speed the engine runs at with the throttle in the lowest part of the range. Disengagement of the clutch in this position would stall many of these machines, it should just be ticking over. There’s an idle adjustment screw on the carb that lets you set the idle.
With the idle correctly adjusted you can then set the throttle adjustment so that it’s linear from tickover through to full revs. You’ll need to have a read of the specific manual for your model of Briggs and Stratton engine to determine exactly which screws perform what function on your particular carburettor.
Mine is powered by a Kirby engine so I can’t assist with the specifics of which screw does what aside from explaining the process. I found I needed to rebuild the carby on mine as it was full of congealed gunk and the float was corroded and required replacement.
There may be someone on here who has better information on this particular engine.
Ironbark
Rover45Restoration, seebok, PFC, barramundi2, Billrfromvic
18,203 Registered Users
Topics12,771
Posts106,862
Members18,204
