1 members (MowingManiac), 5,679 guests, and 1,292 robots.
by Bruce - 30/10/26 08:38 PM
by Bruce - 30/10/26 08:35 PM
#112810 09/09/21 03:30 PM
I recently picked up this mower which I believe is a 1968 New-Utility 160cc.
I have always used a 20" Alroh reel mower to mow my lawn, but have been on the lookout for a rotary to use to scalp my lawn for its annual renovation. I was advised to look for a Victa "Toe-cutter" and last week purchased the mower in the photos.
Until this week I knew nothing of these mowers, but have been enjoying doing some research on this wonderful forum.
My questions for all you Victa experts out there are:
1. Can anyone confirm if this mower is indeed a 1968 model?
2. Does the engine appear to match the frame vintage (ie original?)
3. From my reading the ute's came out in 125cc and 160cc. Is this engine actually a 160cc? (despite the what the sticker says!).
4. Can anyone confirm the correct blades I should be buying for this model?[/b]
Thanks all - appreciate any advice.
G'day Tom,
1 Yes 1968.
2 Yes engine is correct for base.
3 Yes 160 cc
4 Blades LINK 4 BLADES CLICK HERE
The wrong fuel cap on this Victa Utility stands out as does the starter ,the original starter would have been
the impulse starter and the white air filter is a replacement the original one being green.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/77945/brochure-1968-69-range.html
1 member likes this: tomkatoz
I was hoping you'd come and answer maxwestern. I wrote part of a reply with some of those answers such as the starter and believing it to be a 68 160 engine going by 68 being among the numbers and a through bolt being visible, indicating it's not a 125, before accidentally erasing my post. smashpc
I thought, nah, I'll leave it to another who knows every question!
It's good to see a Scotty fan taking an interest in a Victa. There's no reason you can't be into both.
Hello all
Nothing much to add except I am fairly sure that 'fuel cap' is the cap off of the old Castrol 2 Stroke oil bottle they used in the 90s
A good machine nonetheless - I was considering it myself when I saw it on gumtree - but couldn't make room in the shed for another non-catcher mower
Those early Victa 160s from the late 60s are the best. Always sound that bit nicer than, say, a late 70s one.
I was given a later one that was blueprinted!
1 member likes this: Seanoss
Thanks for the replies and info guys.
Being a newbie to the world of 2 stroke victas, can I ask a couple more questions re: the throttle and starting procedure.
As you point out Max, the air filter isn't original and I can tell that due to the fact that it appears to be upside down!
Per the photo attached I can see the words, STOP, SLOW, and what appears to read "CATCH or FAST"
However the throttle itself operates in reverse when the engine is running. Noa big issue but it does appear strange.
So my questions are:
- Do these engines have a choke for starting?
- What's the advised throttle setting when starting?
- How many presses on the carby tickler is recommended.
- Should the ticker dribble fuel when being pressed (it does) or does that indicate a faulty gasket?
Thanks all.
PS : Mowerfreak - Scotty fan???? Alroh fan all the way wink wink
Yes yes, I realised my blunder ages ago but it was too late to correct.
When I see any reel mower, SB screams out automatically.
The Victa two stroke never came with a choke AFAIK, certainly non that I ever used. Maybe the toecutters had one.
It's part and parcel for the tickler to squirt fuel at the bottom. That's telling you it's time to try and start the mower.
Not sure why your throttle is working in reverse. Maybe it's mounted back to front.
Mine with that throttle also work in the wrong direction (ie pull up to rev up, push toward engine to stop).
My starting method is:
Fuel on, press and hold the tickler until fuel squirts out slightly
Tilt the mower onto its left wheels for about 5 seconds (about 45 degrees) - this dribbles a bit of fuel out the top of the main jet into the intake. I have found they start a lot easier this way.
Then set throttle about half and pull the cord.
Put back to idle for a few minutes to warmup and then go
G'day all mower tilting enthusiasts ,
Not a bad idea Tyler to tilt for a quick start ,I usually put a rag under the carby to soak up the fuel from priming
but I hold the tickler down for a few seconds after a steady flow of fuel from the overflow port, so that it pushes
fuel into carby throat.
1 member likes this: twostroker
18,195 Registered Users
Posts106,841
Members18,196
