0 members (), 5,944 guests, and 1,935 robots.
#11090 09/02/09 07:15 AM
Sir
This bolt will not tighten. I`ve tried extra washers-new spring washer even at both ends. It`s supposed to tighten the yellow motor part to the silver shaft. The whole thing is loose between yellow part and silver shaft. Any ideas? :cheers [Linked Image from img291.imageshack.us]
[Linked Image from img291.imageshack.us][Linked Image from img23.imageshack.us]
terrace #11092 09/02/09 09:21 AM
Terrace,
You will not be able to tighten the bolt up as the gap between yellow is not wide enough to clamp on the shaft.
I would put some rubber around the shaft and then slide the shaft back into the motor housing and it should stop any movement. cheers2
Bruce #11093 09/02/09 09:27 AM
Sir
Thank You. Does that shaft come right out? Now i`m not sure what rubber to use, maybe like bicycle tube? Have to be pretty thin eh? aussie
terrace #11097 09/02/09 02:16 PM
Yes the shaft comes out and the bicycle tube should be ok. cheers2
Bruce #11100 10/02/09 01:43 AM
Sir
Thank You Bruce looks like the yellow cover has to be removed and i guess the wires disconnected? Maybe a techs job i`m only an amateur. cheers2 [Linked Image from img131.imageshack.us]
terrace #11103 10/02/09 01:58 AM
Terrace,
It is not hard to do as you only need to undo the cable nut and remove the cable then just disconnect the wire which has a pull apart fitting which will be under the tape. The other wire will come off when you undo the nut holding the throttle cable to the body.
Why pay someone $25 for a few minutes work when you can do it yourself. cheers2
Bruce #11105 10/02/09 02:37 AM
Sir
Thank You Bruce. I`ve removed the main bolt and tried to pull the shaft out but it only moves a little, about quarter of an inch, and then shows resistance and won`t go any further. aussie
terrace #11106 10/02/09 02:44 AM
Have you removed the cable and wires? cheers2
Bruce #11107 10/02/09 02:57 AM
Sir
Not yet but there seems to be something stopping the shaft from moving very far. I don`t think the cables are stopping it. cheers2
Bruce #11113 10/02/09 08:33 AM
Sir
cheers2Yes Bruce i see now, learning all the time. I got the wires off and pulled the shaft out and the diameter of the shaft is just under one inch. Now i`ll have to find a sleeve rubber not too thick that will fit over the shaft and slide inside. Do you think i`ll need something to go right round the shaft. I looked at bicycle tubes and they seem a bit thick. aussie
Bruce #11114 10/02/09 10:38 AM
Sir
Ok Bruce got the shaft out and cleaned it up. Tried insulation and other types of tape but that just gets pushed back when putting the engine over the shaft. Latest i have applied some Selleys adhesive silastic on the shaft and it seems stable but lets see when i want to use the brushcutter. If that doesn`t work i`ll get my son to bring some Sikaflex home from work, that`s supposed to glue anything. Other than that maybe a couple of self tapping screws through the yellow part into the shaft, what do you think? aussie [Linked Image from img5.imageshack.us]
terrace #11118 10/02/09 12:56 PM
Terrace the screw will work as well. cheers2
Bruce #11127 11/02/09 02:14 AM
Sir
Thanks Bruce. I`ll keep the screw option as well. I`m thinking maybe the head of that bolt has bitten into the yellow housing and therefore reduced the tightening purchase ability onto the shaft. After thinking about it there must be something that has caused the thing to loosen. I`ll check further. cheers2
terrace #11132 11/02/09 04:45 PM
Just check for wear on the alloy shaft because if it has been loose for some time it will wear.
Another thing you might be able to do is open up the slot of the yellow housing so that when you tighten it up it will close more on the alloy shaft. cheers2
Bruce #11134 12/02/09 01:56 AM
Sir
Thanks Bruce i`ll try that aussie
18,147 Registered Users
Members18,148
