1 members (Olqualcast), 5,359 guests, and 2,428 robots.
by Bruce - 30/10/26 07:12 AM
#109387 15/11/20 10:41 AM
Need help to identify what model this Rover is as the top cover is missing, I need to tension the starter rope spring and can't work out how to get to it and can't find any thing on youtube.
Any assistance or instructions appreciated.
Buckets
Buckets #109388 15/11/20 10:55 AM
wce Offline
Hi Buckets
It's a Quantum series Briggs and Stratton engine.
wce
Buckets #109389 15/11/20 11:12 AM
wce Offline
The plastic ring sitting on top of the engine cover is part of the fuel tank which you need to get back far enough to get the engine cover off. Take out the 3 small bolts on the inner ring ( pic 3 ) and there is a bolt lower on the side of the fuel tank to take out and shift the tank back out of the way. Remove the 1 small bolt holding the dipstick tube to the cover and twist dip stick out of the way. Remove the engine cover and rewind spring as per any Briggs with that style pull start.
Buckets #109390 15/11/20 01:38 PM
G'day Buckets and WCE
What WCE said or watch this Video
This Rover looks about a 2000 model but they were made for many years so you would need the
numbers that are stamped into the metal engine cover (cowl) to identify the exact year of
manufacture.
Buckets #109393 15/11/20 02:40 PM
Thanks all, that helps immensely, I have now found a couple of videos that are the same as mine to work from.
The first thing I found is one of the white lug thingy"s are missing (see pics) not sure what they do?????.
Am about to pull it apart, will report back soon.
Video -
Buckets #109394 15/11/20 02:48 PM
Yep the white lug thingy"s are the starter pawls that engage with the starter cup when starting the mower.
They are cheap on Outdoorking https://www.outdoorking-forum.com.au/index.p...bvutugp5&keyword=briggs+starter+pawl
1 member likes this: Buckets
all fixed, thanks to all for the assistance.
Buckets
Buckets #109418 16/11/20 04:48 PM
wce Offline
Good work Buckets
wce #109577 03/12/20 10:13 AM
Originally Posted by wce
Good work Buckets
Not quite:
My neighbor bought the mower back yesterday, complaining that when he started it up it only ran for a few seconds and the cutout.
Sure enough started it up and same thing happened, but if I hit the primer just as it was cutting out it would go for a few more seconds, hit the primer again and it would go fine for 2 or 3 minutes ect ect.
The strange thing is this never happened when I repaired it the first time, I even mowed with it for at least 20min to test it.
PS: I found the model number: M: 12F802 Type: 0875-01 Code: 96082759 (Carby is primer type)
Thoughts?
Buckets #109580 03/12/20 07:15 PM
Hi Buckets,
Pull the filter out and give it a rev and jamb you thumb into the throat of the carby, bend the deflector out of the way so you can get your thumb to seal it off and as it starts to die release your thumb and repeat this a couple of times. This can often suck the bit of rubbish through that is causing the problem
Buckets #109581 03/12/20 08:26 PM
Hi Buckets and Norm
If that doesn't work while the air cleaner is off (or remove the complete plastic air cleaner assembly ,3 small bolts) then remove the fuel bowl with a socket and give the carby a clean,no need to remove the carby just clean in situ .
Buckets #109582 04/12/20 11:23 AM
Thanks Norm, Max:
I ended up taking the carb off (it appeared to be in very good condition) and hitting it with carb cleaner and fitted a new carb kit.
Started first go and runs well.
The thing I can't get my head around, is that when I returned the mower the first time it was running perfectly, yet a couple of days later it has this problem??
I'm kicking myself now that when it came back I didn't test it first with new fuel, before I done the carby just to see if it may have been old fuel he was using.
Anyway we will see how it goes this time.
Again many thanks.
Buckets #109591 05/12/20 07:46 AM
Hi Buckets,
don't be too hard on yourself, old fuel was not the problem, it is only a few weeks since he got the mower.
Nangus, thomas18, jessesharp43, ELStretto, David Bolger
18,193 Registered Users
Topics12,767
Posts106,836
Members18,193
