2 members (Grahamp, DeanVR4), 4,768 guests, and 1,110 robots.
#109174 31/10/20 05:38 PM
Hi guys
I'm new to the greenfield anniversary 12 model
Having a problem where I have to push real hard to go forward and pull foot pedal back by hand.
When im mowing it real struggles to go backwards
Is it an adjustment issue or the cork in discs worn.
Thanks in advance
Hi Gav,
could be both but start with the adjustment first. When they are not adjusted properly they hurt your ankle because you are trying to push/ bend it more than it is able to. The adjustment is not easy to get to as it is just inside where the pedal shaft enters the body. There is also the probability the rods/linkages are worn. Without having a method of getting under it I usually find it is easier to drain the oil, remove the battery and tip the mower on its side with the pedal side down so you can see what is going on down there.
Thanks mate I check that out. I checked the cone disc s cant see any cork wonder if clutch gone
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
