0 members (), 2,533 guests, and 456 robots.
Hello to everyone, I hope you are all well and safe.
I have a Atco Lightweight model 1952 circa. It is fitted with a cone clutch of which I am not sure how this works.
It appears to me that the part that has the fork attached slides on the shaft. Inside this part is a woodruff key to make the drive turn.
Does this part slide over the woodruff key?
On the end of the Villiers motor there is a drive coupling to connect to the clutch. This coupling has only 1 arm. Should it have 2 arms?
The arm that is presently there has been welded to the coupling body, is this normal?
I have attached some photo's to try and help explain.
Many Thanks to all of you who contribute.
Arty
Hello Arty
That's a great resto taking place there.
It is not so usual to see these larger domestic Atco reels.
I cannot answer your question, but I'm hoping a member will know.
There are some manuals available at the OLC here:
https://www.oldlawnmowerclub.co.uk/technical/manuals/search
Atco Specialist
Hi Arty,
The drive dog should have two spigots with a hole in each for a small stiff spring. The clutch body yoke fits over the spigots. Photos attached.
Kind regards,
Sir Chook
Arty, in answer to your first question, yes the clutch cone slides on the shaft to lock into the clutch housing thereby giving drive, the fork on the lever is what activates it.
Beech.
18,144 Registered Users
Members18,145
