3 members (AMP, MowingManiac, Buckets), 1,903 guests, and 525 robots.
Bushranger cylinder mower
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Sanli Redback Ret Spring
by NormK - 22/01/26 02:05 PM
by NormK - 21/01/26 09:55 PM
Rover Thoroughbred Model 85
#107624 02/08/20 10:49 PM
I found this 4.2L size fuel tin (left) in a kerbside rubbish pile and appears in sound condition with a tiny remnant of fuel at the bottom with some little bits of debris.
The 5 litre one on the right has a leak at the bottom which I found out the hard way after filling up at a Caltex! Fortunately I had a plastic box I was able to put it in until I got home.
I want to dispose of it but is it valuable on the collector's market?
PS: what's the best way to clean out the old fuel and debris on the bottom?
G'day MF,
Most small bottom leaks in these cans can be easily repaired with soft solder, and a good soldering iron [not direct use of a flame torch].
I have a BP Zoom 25 can I need to get around to repairing, that will require use of an old timer soldering technique called 'a tinker's d_a_m'... grin
The underscores are just to get around the forum's auto censorship... crazy
Hi Mf ,Gadge and all,
The fuel tins look like they are worth about $20 .
The Victa tins from the fifties are about $50 for an average one.
Hi Gadge and maxwestern,
how thoroughly do you have to clean the surface on the outside and what about inside preparation if any?
G'day MF,
Not much prep you can do on the inside [there is a post-soldering internal passivation that's worth doing, which I'll go into later on]; but the outside surrounding the hole/s [say 5-6mm at least] has to be clean bare metal, free of rust, so that it can be 'tinned' with solder.
I guess I need to get onto my Zoom can job, and take pics as I go for a write-up... wink
I'll have to think a bit about what surface prep techniques to use/demonstrate, as I have some options available that most ODK'ers wouldn't have.
17,805 Registered Users
Topics13,058
Posts107,236
Members17,805
PHP: 8.3.28 Page Time: 0.048s Queries: 27 (0.041s) Memory: 0.6432 MB (Peak: 0.6887 MB) Data Comp: Zlib Server Time: 2026-01-22 23:18:57 UTC
