2 members (auProspector, Bruce), 2,231 guests, and 1,900 robots.
#105381 20/04/20 10:35 AM
wce
Offline
Morning members
Picked up this 18 recently, had a search through the information here but there seems to be a lot of variations so I couldn't accurately place the model/year.
It has a Victa Automatic handle bar plate but I can't see to much auto about it. The stamping on the lower crank case looks like a 1 but not on the right angle. It has the choke control on the air filter body.
Maybe it's a bitsa ?
wce
wce #105383 20/04/20 10:49 AM
G'day wce,
That one could well be a 'stripped Automatic' - i.e. one that has had the Automatic front/rear throttle control flaps and associated bits removed. It certainly has the [busted] extensions of the front and rear axle housings, that were unique to the Automatic.
That would be because, back in the day, a common quickie method for removing the flaps was to just whack the flap pivot shafts with a hammer...
Have a close look at the carby top - the Autos had two throttle cable entries there.
If your machine actually left the factory as an Auto, one will have been plugged, if it's there. The Auto handle plate is a fairly strong indication, that this was likely the case.
wce #105386 20/04/20 12:55 PM
wce
Offline
Hi Gadge
Thanks for the info, nothing visible on the very top of carby but there is a brass looking plug/screw about a quarter around toward the rear from the spring clip hole, is that what you are referring to ?
wce
wce #105389 20/04/20 01:50 PM
Screw will be the slide guide to keep the slide in the correct position and stop it rotating
wce #105396 20/04/20 03:45 PM
It’s a Model 5 Series 2 or 3, engine number suggests a 2.
wce #105415 21/04/20 09:06 AM
wce
Offline
Thanks Gadge, Norm and Paul
That would make it a mid to late fifties vintage ?
wce
wce #105424 21/04/20 10:19 AM
G'day wce,
Yep, in that range.
You may well curse me for this, but ODK has a huge past thread on the niceties of distinguishing Victa models of this era.
This CyberJack post is a very good intro, and contains a link to that thread...
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/galleries/94790/victa-automatic-guide.html
wce #105428 21/04/20 11:12 AM
G'day wce,
This Victa Special is a bitsa,it's from around 1959 to 1961 ,the engine number is from an earlier Victa Special.
This mower never had auto flaps the base does not have the alloy extensions to hold the flaps in but
someone has installed the earlier axle locator brackets with the extensions for the flaps.
There are 2 types of auto badges ,the earlier badge is smooth alloy around the Victa Automatic
the other badge has a rough texture on the plate.
Because this base has no edger slot it is the last of the Victa 18 alloy base mowers sold.
http://www.vintagemowers.net/Victa_Specials.php
wce #105461 22/04/20 09:19 AM
G'day folks,
Good to see folk who really know their early Victa 18's chiming in here. cool
Not like me - I have some ODK threads on the topic bookmarked, but I have to go and trowel through them to dig up info...
wce #105466 22/04/20 11:32 AM
wce
Offline
Good morning all
No substitute for experience regarding these older models, some great reading to be done on this topic, probably enough to get through another couple of pandemics.
I have had some lube in the cylinder for a couple of days but no joy, engine is locked up like Fort Knox, might have to administer the last rights to this one.
wce
wce #105504 23/04/20 12:11 PM
G'day wce,
What I'd do here, is to make up a brew of 50/50 by volume Acetone and Automatic Transmission Fluid [any type of ATF], and tip some down the spark plug hole - as much as will go in. Then prop the engine up, to keep the cylinder vertical, and leave it for a week or so.
This is a much favoured technique in the Vintage Engine Restoration community, for freeing up piston/bore seizures. And some of those engines come up OK, after decades of being seized...
wce #105506 23/04/20 02:11 PM
wce
Offline
Hi Gadge
Ill give it a go, nothing ventured, nothing gained. I put a reasonable amount in and had it sitting on it's nose for a couple of days. Is it worth pulling the head off and having a look ?
wce
wce #105507 23/04/20 03:46 PM
+1 on the 50/50 Atf/Acetone - have heard of others using Diesel, but the 50/50 is just the best mix.
Gadge, quick question. I have got my new bottle of acetone ready for the next time I need it - last time I did it I just carefully mixed a little in a tin (as the acetone melts some plastics like PVC).
Do you know of anything safe to put it in that will act as a 'sprayer/applicator' of some description - I figure it would rot the seals out of a regular pump oil can
wce #105511 23/04/20 07:10 PM
G'day Tyler,
I don't know of any 'piston type' pump unit [outside of very exy 'lab gear grade' glass cylinder/Teflon piston dispensers] that can act as an applicator/sprayer for this mix - its solvent properties are just too aggressive.
The two simple items I have successfully used for 'localised squirt application' of it are these;
1. A small 5-20mL 'two-piece' hypodermic syringe - these don't have a rubber piston seal, but are hard to find, even for a labrat
2. HDPE 'transfer pipettes' - readily available via FleaBay for cheap, e.g. https://www.ebay.com.au/b/Transfer-Pipette-Pipettes/26417/bn_7037612639
wce, give the Acetone/ATF brew a go, before you pull the head - the acetone will not evaporate off as fast as it would from an open bore.
wce #105513 23/04/20 07:44 PM
Thanks Gadge - I have got a few of those pipettes I use to squirt some petrol down the carby for troubleshooting.
I'm thinking one of these https://www.ehi.com.au/cesco-shearers-oil-can-1pc - although if I knock it over I could be stuffed haha
wce #105519 23/04/20 09:36 PM
wce
Offline
The mixture is in and it's on it's nose, from here on in nobody know's.
wce
Tyler #105542 24/04/20 05:05 AM
G'day Tyler,
Don't think the seals in that would handle Acetone, but one of these might work; https://detailingshed.com.au/products/ik-alk-1-5-alkaline-alcohol-and-acetone-sprayer
Edit: I've done a bit of further research, and there aren't many 'rubbery' seal materials that can handle both the ATF and the Acetone. Elastomer types FFKM and ETP ; that's about it. And Teflon, but that's a lot harder material.
I also make use of a similar but less volatile mix, as a general 'penetrating lube/cleaner'. It's called 'Ed's Red', and was originally formulated for firearm cleaning.
Simple recipe; equal volumes of Acetone, Kero, Mineral or Pine Turpentine, and any ATF.
If you want a 'less aromatic' version, just use 'odour-free' Kero and Mineral Turps.
18,091 Registered Users
Topics12,750
Posts106,781
Members18,091
