0 members (), 2,741 guests, and 298 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
wce #105483 22/04/20 09:40 PM
G'day WCE and Mystyler
Brilliant!
These earliest of Imperials were the better mowers.
Note the larger clutch ...
Low idle RPM, and higher torque, and a larger clutch
made the 4-strokes the better machines - in my view.
The 2-stroke Imperials were ridiculously sensitive to
throttle inputs ...because of their 2-stroke engine.
They lacked low-down torque.
Clearly, Victa understood this, and made the throttle on
their 2-stroke Imperials act as an on-off switch.
Maybe I have said too much ... eek
Very good.
wce #105488 23/04/20 01:25 AM
wce, I love a good Imperial. And Jack is right, that's an unreel (ha) example.
Jack, thank you for pointing that out, regarding the clutch! I had "noticed" there were clutch differences, but didn't put two and two together to work it out. As much as I hate to admit it, cylinder mowers are probably best left to electrics or 4 strokes. But I'd love one with a 125cc, because I'm a tragic. They tried to solve the problem by putting a spacer under the head to drop the compression didn't they? And these lower comp motors were the only two stroke Victas to use 50:1?
Mystyler #105502 23/04/20 11:11 AM
G'day Mystyler,
Yes and yes. They also used a 'special' un-governed version of the G3 carby on these.
wce #105525 23/04/20 11:21 PM
G'day Mystyler and Gadge
Many thanks Gadge for a great summary of the Imperial 125cc.
In the modern era, the Ecotech Power Torques used 50:1.
Also, the Victa Jet outboards ran this mix. This was BP Outboard.
Gadge knows this area far better than me. smile
wce #105528 23/04/20 11:33 PM
I suspect that these "special" G3s are even harder to get parts for. Why ungoverned?
wce #105530 23/04/20 11:52 PM
G'day Mystyler
The answer for me is clear ... Victa saving money.
The Imperial 125cc acted as Victa commercial engines did ...
Off - Idle - On.
The G3 was designed for vertical shaft Victas.
Turning the motor 90 degrees required serious re-thinking - because the
air vane had to act within the air shroud (cowling).
How could you get an air-vane carby work when you rotated it 90 degrees?
Answer: too expensive. Forget governing altogether.
Are the parts hard to get?
... No
All Victa did was bung the governor aperture. [item 7]
wce #105534 24/04/20 01:24 AM
Hello Jack, and thanks. Victa saving money is a common theme. Can't really blame them though, I suspect other companies would have done similar things if needed.
What I don't fully understand with these ungoverned 125s is how Victa prevented home owners from ruining their motor from over revving. Was it simply a matter of the carby not being able to supply enough fuel? A hot, high revving and leaned out motor is not a recipe for success. I guess the G4 came too late for the Imperial in two stroke guise.
wce, I apologise for talking about the two stroke Imperials. I just have a massive soft sport for them as they're a bit unusual. I'd still have a Kirby powered one though. grin One has actually popped up not to far from me for $80. Little bit rough...and I need another project like a hole in the head.
Mystyler #105536 24/04/20 01:45 AM
To a degree, you probably could. But back then, when you paid a fair wack of your income for a quality machine, you were more inclined to look after it.
Plus, as they weren't seen as just an appliance back then, and people had probably grown up with ungoverned 2 stroke rotaries, which you could really get racing.
Of course in any generation there are either a**eholes or idiots who are too ignorant to know/care - just seems like the %age has increased exponentially haha. Another curve we need to flatten
Plus, with a reel mower, you have a relatively constant load - rev it up to engage the clutch and you are always have the reel spinning.
Unlike any of their rotaries - you aren't going from unloaded to plunge into 3ft high weeds. You are manicuring the lawn - its not a slasher. Plus, the engine is right up in the open air and not squished under a 1l tank of fuel with a big cowl crowding it like a rotary.
And remember, the full cranks allowable RPM was listed as up to 4200rpm (utility) - at which point, as you say, you would probably run out of fuel and maybe some ignition point bounce may be involved
CyberJack #105539 24/04/20 05:09 AM
G'day Jack,
BP Zoom Outboard, actually.
As far as I can recall, the Victa Jet outboard ran 'BP Zoom 25', same as the rotary mowers. We ran one of these on a 10' aluminium punt for a while in the 70s, and I don't recall having to mix special fuel for it.
Noisy bloody thing with the standard Victa muffler, it was. A straight-through stainless steel [90 deg bend + milking machine milk line tubing] underwater outlet exhaust pipe quieted it a lot.
The bulk BP Zoom 25 drum in my family's OPE shop supplied the fuel for our Victas, tho' we did mix up some 20:1 fuel, using Castrol Super Outboard 2-stroke oil [as that was what Mobilco specified], for our Mobilco Echo saws.
wce #105552 24/04/20 11:09 PM
G'day Gadge
Many thanks for keeping me honest.
Yep, the Victa Jet does appear to run on a recommended BP ZOOM 25.
17,902 Registered Users
Topics13,076
Posts107,348
Members17,903
PHP: 8.3.30 Page Time: 0.082s Queries: 37 (0.074s) Memory: 0.6826 MB (Peak: 0.7540 MB) Data Comp: Zlib Server Time: 2026-04-02 04:23:41 UTC
